Over Fueling Problem
hi everyone i have a 1995 r33 gtst, only things done are an apexi filter, full 3'' turbo back (no cat), and a fmic, hks blow-off..... so car idles fine and cruises ok but once you start pushing on the gas pedal my afr's (its a narrow band) just start droppping, to as low as 10 to 1 and as soon as i hit 5 psi i hit fuel cut. So my buddy has nistune and we plugged his laptop into my car and watch what its doing and everything looks normal expect for my maf and injector which under any kind of load max out, so we thought the maf was defective and i sourced a compatible maf and install it.... no different, try removing the blow-off and installed the factory one..... no difference, checked all the piping for leaks.... all is tight and no leaks at present time.... has anyone one had this problem or something similar? the motor is a r33 series 2 motor.
If those are your only mods then it wouldn't be your MAF, unless you're talking about your AFM? MAF is just used for the stock boost gauge. But have you checked your fuel pressure regulator?
Try swapping the fpr with a known working one. Probably not the cause, but best way to eliminate problems is to start with the cheapest solutions and work your way up
I had an identical problem with my 33 a few years ago. Turned out to be a boost leak in one of the silicon hoses. Looked 4 times before i found it. It was a split located in a spot where I had to pull the pipe out to see it :verymad:
At what boost/prm is the afm hitting 5.1v?
it depends on the rpm its anywhere between 2-4k and i cant get pass 5 psi
like you said it could be a boost leak and it could be one of the silicon couplers i guess i could recheck them again, all the silicon couplers are new
similar issue to mine, seem to be hitting R&R. Car seems flat through the rev range even though its on standard boost (confirmed by an aftermarket boost gauge) reset ecu, car came alive again, after a couple of days was back to its normal self
 Share
    • Because there is still an engine underneath that turbo. PSI is not a measurement of power, it's a byproduct of resistance. What would be really decent is to have a CFM gauge on the output of a turbo to see how much it's actually pushing. 21psi (as an example) is not the same amount of air at 3000rpm as it is at 7000rpm, even if the boost controller is controlling boost at "21psi". The engine is inhaling and exhaling way more air at 7000 than at 3000, even if it's less efficient.
    • don't want anything more or less, I don't really understand why the torque still goes up to 6000-6500, while the boost peak is around 4000. if it only comes from the cams or from the boost controller etc.
    • I'm not sure you understand the physics of what you are asking. Can you draw on the dyno graph what you want to have happen? I'm thinking this is a functional impossibility here, unless you chose a turbo literally so laggy that torque is at max at 7000rpm and artificially choked prior to that. Power and Torque are intrinsically linked. Power is just Torque over time. What you're really seeing in the torque graph is "Power per RPM" if that makes any sense whatsoever. You still get more power at 7000rpm than 5000rpm, because it is "power per RPM" and you have more RPM. at 7000 than you do at 5000. You still feel more powerful at 7000rpm. The torque graph will influence the rate of power increase per RPM.
    • Welcome!  If possible,  would live to see some pics. How long was it away getting the work done? Hopefully it feels like a new machine.
    • yes indeed the graphic format makes a visual difference but there is on average 120nm more between 4000 and 6000rpm on the curves it is not nothing. you are right, the cams influence the torque curve. I was able to chat with one of the Hypergear tuners, he confirmed that a boost control allows you to manage the pressure after the spool. the absolute pressure (psi) on the graphics is measured where? It seems that the cams affect the maximum pressure depending on the regime but I may be wrong.   not pleasant to drive before 4000? if we spend our lives between 1000 and 3000 rpm as you say then we might as well just run diesel turbos
