Little bit stuck on this one. for the record its a R32 skyline
had a flat battery and i got a mate to put jumpers on the battery with a fully charged one and terminals got crossed up the wrong way.. a relay went nuts and popped 3 fuses and the ECU.
put a good ecu in there and replaced all fused and went to start it and it blew another fuse straight away. Its the fuel pump fuse under the dash. some where in the fuel pump circuit it has a dead short. have unplugged the pump and it still blows. unplugging the relay stops the fuel blowing.
with the ECu disconnected and all efi relays unplugged. it still does if i manually earth out the fuel pump relay it so i have eliminated the engine loom side of things.
i'm a little stuck on it.. the fuel pump relay has two sets of wires.. theres the power wire that comes from the fuse itself.. thats blue/black and doesnt appear to have condiduity to the chassis (if it did it would blow the fuse all the time not when the relay is activated) the black/yellow wire that gets powered by the relay to provide 12V to the fuel pump DOES however have a dead short to the chassis. now im stuffed if i can find out where the wire goes to the front of the car as it branches off in the boot to the fuel pump and to the front.
any help would be great!
Edited by Simon-R32
https://www.sau.com.au/forums/topic/332087-wiring-fault/
Clearly the dead short is between the relay and the fuel pump connector (or maybe a broken relay - But highly unlikely). Pain in the arse to find that short, better off running a new wire from the relay to the fuel pump. Don't forget to cut the old wiring BOTH sides, otherwise you will still get the shorts. IF you decide to pull power from another wire for what ever reason, MAKE SURE you fuse it :verymad:
https://www.sau.com.au/forums/topic/332087-wiring-fault/#findComment-5388279
if you disconnect the wire where it runs into the relay and also from the pump (like you have) then switch it on, does the fuse blow? if not then the short is in the wire from the relay to the pump. im pretty sure you've worked out thats the issue anyway. i suspect your gonna have to pretty well replace that wire entirely.
if you get a wire hot enough like you probably did, you can melt the insulation off it pretty much all the way along it without too much effort. therefore it can have a million shorts all along its length.
im not an expert on the basic layout of an r32 but i'd asume that under the drivers kick panel there will be a large plug that the loom to the rear of the car connects to. if so disconnect it and see if the pumps wire has shorts there. at least it will determine if the short is before or after the plug. if its after (closer to the plump) it will be far less of a pain in the arse to replace.
https://www.sau.com.au/forums/topic/332087-wiring-fault/#findComment-5388478
If you are trying to chase a wire that is shorted to the chassis, you will find a hell of a lot of them. they are called grounds.
Run a new wire from relay to pump neatly under the carpet etc. and get back to driving.
im not not sure if your being serious here or not.. but a ground wire or earth wire is a lot different to a power wire that it shorted out. a dead short is what i have and am trying to find.
but yes.. running a new wire looks to be the fastest way out of this problem
https://www.sau.com.au/forums/topic/332087-wiring-fault/#findComment-5389734
    • Cool to see you're on the forum man, think you've met my twin brother a few times (Brent).
    • Yeah...but NA Mercedes V12.
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
