Little bit stuck on this one. for the record its a R32 skyline
had a flat battery and i got a mate to put jumpers on the battery with a fully charged one and terminals got crossed up the wrong way.. a relay went nuts and popped 3 fuses and the ECU.
put a good ecu in there and replaced all fused and went to start it and it blew another fuse straight away. Its the fuel pump fuse under the dash. some where in the fuel pump circuit it has a dead short. have unplugged the pump and it still blows. unplugging the relay stops the fuel blowing.
with the ECu disconnected and all efi relays unplugged. it still does if i manually earth out the fuel pump relay it so i have eliminated the engine loom side of things.
i'm a little stuck on it.. the fuel pump relay has two sets of wires.. theres the power wire that comes from the fuse itself.. thats blue/black and doesnt appear to have condiduity to the chassis (if it did it would blow the fuse all the time not when the relay is activated) the black/yellow wire that gets powered by the relay to provide 12V to the fuel pump DOES however have a dead short to the chassis. now im stuffed if i can find out where the wire goes to the front of the car as it branches off in the boot to the fuel pump and to the front.
any help would be great!
Edited by Simon-R32
https://www.sau.com.au/forums/topic/332087-wiring-fault/
Clearly the dead short is between the relay and the fuel pump connector (or maybe a broken relay - But highly unlikely). Pain in the arse to find that short, better off running a new wire from the relay to the fuel pump. Don't forget to cut the old wiring BOTH sides, otherwise you will still get the shorts. IF you decide to pull power from another wire for what ever reason, MAKE SURE you fuse it :verymad:
https://www.sau.com.au/forums/topic/332087-wiring-fault/#findComment-5388279
if you disconnect the wire where it runs into the relay and also from the pump (like you have) then switch it on, does the fuse blow? if not then the short is in the wire from the relay to the pump. im pretty sure you've worked out thats the issue anyway. i suspect your gonna have to pretty well replace that wire entirely.
if you get a wire hot enough like you probably did, you can melt the insulation off it pretty much all the way along it without too much effort. therefore it can have a million shorts all along its length.
im not an expert on the basic layout of an r32 but i'd asume that under the drivers kick panel there will be a large plug that the loom to the rear of the car connects to. if so disconnect it and see if the pumps wire has shorts there. at least it will determine if the short is before or after the plug. if its after (closer to the plump) it will be far less of a pain in the arse to replace.
https://www.sau.com.au/forums/topic/332087-wiring-fault/#findComment-5388478
If you are trying to chase a wire that is shorted to the chassis, you will find a hell of a lot of them. they are called grounds.
Run a new wire from relay to pump neatly under the carpet etc. and get back to driving.
im not not sure if your being serious here or not.. but a ground wire or earth wire is a lot different to a power wire that it shorted out. a dead short is what i have and am trying to find.
but yes.. running a new wire looks to be the fastest way out of this problem
https://www.sau.com.au/forums/topic/332087-wiring-fault/#findComment-5389734
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
