hey guys lookn for a s13 sr20det original manual good body work 1st car for ma brother please contact me on 0411401942 harry . if you got one or simply send me the thread thanks .
https://www.sau.com.au/forums/topic/332090-wanted-s13-sr20det-manual-melb/
hey mate i got a 180sx sr20det red top if intrested.
