Probably a simple question but I'd thought I'd throw it out there.
1. The camera needs 12v that obviously you don't want running all the time so I would pressume you could bum it of the reversing lamp circuit??
2. The head unit has an auto switch function that puts it on the units reversing camera mode with 12v in. I could install a rocker switch but where could I get 12v from in the cab that only is available in reverse?
I don't think there is an ECU pin or fuse ot dash indication. Any tips?
Cheers
Edited by ricknismo
the reverse light is of a separate relay not through the ECU so find the relay and wire it up to the HU and u could also add a rocker switch so the camera could be turned on even if the car is not in reverse or to disable the camera. its up to u how u exactly want to wire it. note i guess u could get away without the added relay but i have never installed a camera so i wouldn't know
and does the HU have a 12V out for a camera ? if not use the above im guessing but wire it to the camera as well?
If the camera is of the acc that means it would be on all the time when the car is on and as it is a night one also the little leds would be on when not needed.
Anyone know where the 34 GTR reversing relay is?
You can piggy back power off the reverse lights if you just want it to work when in reverse depending on current draw?
I use a 8 channel external video switcher, but mine has a few extra sources and screens to deal with.
you can get one for under 30 bucks if you look around. or hook up a relay to switch it on . search for Bosch relay guide. it has a lot of good ideas in it.
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
