1. R34 GTR, Stock exhaust, cat back ,$50
2. R34 GTR/GTT LED look alike Tail lights AS New , $200
3. R34 GTT OEM Clutch + plate used but still in very good con. . ,$50
4. R34 GTT Front sway bar, $50 (good up grade for r33's)
5. R34 GTT 4 OEM Suspensions. (no leaks) , $50
6. NISMO S-Tune, Front brake pad, (lot better stopping performance- 100 times better then stocks), only used for 5000ks. as new $250
7. S15 tail lights (like new) , $100
8. HKS pod kit, (SR20DET) (the pod it self will fit RB as well), $50
thanks
Will post wiht extra cost.
Any offer! please PM me... Quick!!!
https://www.sau.com.au/forums/topic/332151-cheap-gtt-parts-nismo/
7. S15 tail lights (like new) , Sold
thanks
2. R34 GTR/GTT LED look alike Tail lights NEW , $150
6. Rear and Real NISMO S-Tune, Front brake pad, with box (lot better stopping performance- 100 times better then stocks), only used for 5000ks. as new $200
thanks
  • 5 weeks later...
3. R34 GTT OEM Clutch + plate used but still in very good con. . ,$40
4. R34 GTT Front sway bar, $30 (good up grade for r33's)
6. Rear and Real NISMO S-Tune, Front brake pad, with box (lot better stopping performance- 100 times better then stocks), only used for about 5000ks. as new $170
8. HKS pod kit, (SR20DET) (the pod it self will fit RB as well), $40
Will post with cost.
Any offer! please PM me only... Quick!!!
  • 5 months later...
still got the lights rear lights? msg me asap cheers 0403673876
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
