so gota rip the head off tomorrow...
any last min advice people??
i no i need to do the following..
remove turbo
timing belt (and all the bits req to do so)
split the intake manifold in 2... are these gaskets like the turbo side ones? easy to pull off? or will they need replacing?)
remove aac
remove crossover pipe, coilpack look etc etc
intake cam wheel
any other tricks anyones got?? anything to be careful of?
what should i use to clean off the tips of the pistons? some one said brake cleaner, as its harsh and evaporates quickly.
and to put it back togeather, just set all 3 markers up and drop it on?
while shes off i want to do a few bits and peices aswell... port and polish... is it really worth doing cams? and any thing eles?
ive been quoted 1400 :S for port and polish, all new valves and guides?? bit steep? i need to remove/refit too!
thanx guys!
https://www.sau.com.au/forums/topic/332179-removing-the-head-from-rb25/
Port and polish is necessary for a n/a engine or for the very top hp engine - save your money for the turbo and just turn up the boost.
kiwi ive put a hks 2535 on... u dont rekn its worth port and polishing???
rodders... where can i get a can of that stuff from?? bull at a gate FTW!
I would five ya a hand but I'll be trying to get mine back together. Sell ya 2535 forget the port n polish and buy a 3076 for 2g. Depending on how much other cash u gota spend first.
ditto on patience.
I've only done this on an R31 single cam 3.0l & VC blue 202 3.3 single cam.
Got the workshop manual?
- You will need to check the torque settings when putting it all back together and
bolt back up in the correct sequence and nm.
- Probably want to to take of the rocker covers off in a week and re-check the head bolts for
correct nm.
-just put my head under the bonnet, looks like you could take the turbo and turbo/exhaust manifold
off as one piece, once all the heat shielding and other pipes/crap is cleared out of the way.
Unbolt the rear of the turbo where it attaches to the exhaust pipe.
- get a good torque wrench.
- get a fine scrapper for cleaning of gaskets where needed. (be very very gentle, don't want gouges!)
- 600 or 1200 grit sand paper to clean of remaining gaskets. (be very gentle don't want uneven surfaces)
- may not need to replace the inlet exhaust gasket sometimes they are not baked on like
head and exhaust gaskets.
But probably best to go buy all of em before staring the job just in case, if you don't use some
you always have a spare(s).
- just some petrol on a rag for cleaning or metho.
And if ya brave after job done have a shot of metho :/
Edited by Stagea_Neo
i have done lots of heads and the best way is to leave all the manifolds on untill you get it on to the bench
dont forget to put the motor to top dead center before you start taking the timing belt off
should only take about three hours with basic hand tools to remove the head
you should find out if the head bolts are touque to yield if so you will need new bolts
hi all..
so pulled fair bita stuff out today...
currently the engines stripped down... no turbo, injector stuff, intake mani, timing belt..
had a quick look under the rockers (weather started to turn)...
from here what do i need to do??
-take the cam wheels off... (wheres this bolt every1 talks about?? at 1 and 7 oclock?0
-undo the U shapped things holding the cams in? is shit going to spring out or anything?
- do i need to drop the oil?
-the allen keys in the spark plug valley, these are going to come out yeah??
-and could only see the odd allan key under the rocker cover... no bolts n stuff?
to put it all back together... i just set my 3 markers up and drop the head on yeh?
is there any way to clean up inside while in there?? i just put fresh oil in it when i did the belt the 1st time... but in the rockers theres fair bit of ugly stuff...
thanx all :D
I'm guessing with the RB, but with most cars you don't have to remove any of the stuff in the head to get it off. Leave the cams in, no need to undo the "u-shaped things" holding them in.
The allen key bolts *might* be the bolts holding the head in. Once again, it's different between different cars and engines - some use regular (but high tensile) bolts with standard head, some use allen keys.
Drop the oil and replace it when you're done. You do not want to find out too late that there are ANY fragments of metal floating around your engine. Better to be safe than sorry.
Adam, you will have bent valves, so the cams do need to come out. Simply undo the u-shaped caps little by little and evenly across the length of the camshaft. Cam gears do not need to come off. Once the head is off and cams out, pour fuel/turps or other thin liquid to see where your leak is, if its not obvious by visual inspection. When you know the valves that are bent, mark them so the cylinder head guy/mechanic will know which valves and guides to change.
I have a valve removal tool you can borrow if you want to remove the other valves also (and/or remove the bent ones and replace yourself), and clean the carbon build up from them.
Or bring the whole head to me, I can remove the cams, and I'll see what can be done to tidy up/fix the head/valves (at whatever cost). I could remove the cams, identify the bent valves, check those guides, get new valves, get head faced (no porting) and possible valve guide replace, remove and clean all remaining valves, insert all valves, seat them in place, reinstall cams and torque caps accordingly. I've disassembled many, many heads over the years.
EDIT: I'm in Perth from Friday to Monday, so unavailable then.
LOL, I should have been more specific in saying that to remove the head you don't have to undo the caps. You will have to remove them later to get to the valves, as Ruby has said.
ok...sounds good guys thanx.
but i do believe my cams will need to come out... as engine isnt at TDC... so cams are going to get in the way i think...
ill undo the u shapped bolts... then go from there...
goldzilla i changed the oil while doing the timing belt round 1... so the oil in there hasnt been used yet... is it still a good idea or just leave it?
ive braught a new head (60ks old) so im just going to take that up to lewis engines and let them do there thing with it
do i NEED to face/machine the head b4 re install? if its just a might as while its there then i will i spose
braught new exhaust and intake gaskets today... with the 2 manifold bolt ons.. do i do the same as head (tighten up from outside in?)
and with any of the 3 (head and 2 mani's) do i need to get all bolts to bight. then go back outside in with more pressure, then back again for more? or just fully do them up the once??
worthy of changing any studs bolts etc etc while shes apart?
thanx guys :ermm:
ok so i today i had a chance to start to get the head off
so far ive taken out the 10mm hex key bolts in with the cam shaft...
now there the 3 prick 10mms to go...
i believe i have taken one off... its turbo water line, bracket, with a 1 inch or so bolt... is this one of them?? or do i need to go deeper?
theres one nere the intake cam... does the cam wheel need to come off to get to it??... if yes, can you take the cam wheel off without taking the whole cam out... the bolts seem to be on the inside, unlike the exhaust wheel,
and where the feck is the 3rd one at 11 oclock???
head doesnt seem to be NEAR loose yet >_< i do have a bit of weapage of oil where its going to split,,, this means there oil there,,, but is the head gasket higher then the oil level? (im hoping this is just excess around the engine oozing out.
this is a pic of an rb30, with the bolts im talking about...
Ok so heads off... Piston 2 is gouged real bad, how can I tell if the boar is gone too?? It looks good but not sure by eye I spose. 2 intake valves were snapped off and have been smashing round. To get the piston out. Just go threw re sump upwards... Any tricks, do's do nots??
I'll need 1 piston, I'll need to do all 6 to keep it even yeah?? How can I clean up while I'm in here!?
Thanx boys :D
I know you have already bought another head, but you might be better off getting a complete long motor so you do not find any other nasty surprises
It will have to be a stagea AWD motor, not a R34 donor as the blocks are different to suit the sump.
If the head is already off, it will be pretty simple and quicker to remove the short motor now than trying to replace a piston from below.
thanx darrin i just posted up about this issue...
where am i going to get one tho :thumbsup:.... its an easy swap over for the head ive braught/getting ported and polished? or do they need to be matched up or something
pics of the current setup!
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
