Not many people drag 34's.. or have modified ones.. You see plenty of 33's at the drags, but not many 34s. Guess people are afraid of breaking them
I witnessed both those 13.7's :( they were achieved with the usual boost up, but otherwise fairly stock.
https://www.sau.com.au/forums/topic/33218-r34-gt-t-14-mile/#findComment-667006
Was mine and eric dont beleive i ran 13.7 with fmic zorst pod and twin plate.On stock boost after dale advanced timing a little.sent him my time slip but its still beyond him.u and dale seen it so if ya could tell him u were eyewitness
english translation of this please????
https://www.sau.com.au/forums/topic/33218-r34-gt-t-14-mile/#findComment-669419
Erik refuses to accept that my car ran a 13.7 on stock boost.With only these mods zorst,fmic,pod,twin plate clutch.thats why he asking bout the 13.7 mile run"Heheh , predator can you source the name and mods with 13.7 run?".So i was just asking if they could tell him they witnessed the run.ALso he tells me that he is buying your car for 35k franks?is that correct?
https://www.sau.com.au/forums/topic/33218-r34-gt-t-14-mile/#findComment-669424
nah man, you got me all wrong - good on R34GTT-R he's got the hardware and he will go well!!! it doesn't take much to know he's got a quick car from the mods he has! :D
i'm not challenging anyone, my motorsport is all about fun and learning from one another :mad: plus, my car is not aiming to be a drag monster i like a balance of street and circuit.
ben's HPI-34T is the car to catch...
https://www.sau.com.au/forums/topic/33218-r34-gt-t-14-mile/#findComment-669512
I got some of HPI-34T soul in my car.My posts are because it shits me that he is telling me my car cant do that when it already has.I like all lines and ppl that are enthusiasts about there car.Not people telling me that my car cant do that because there getting owned by there mate in a 33 that has the same mods as there car./rant over
franks u got full whiteline kit in ya car did you do any circuit before ya fitted suspension and then after and if so what sort of time shaving did you acheive ?
https://www.sau.com.au/forums/topic/33218-r34-gt-t-14-mile/#findComment-669522
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
