hey guys
got these 3 things up for sale
1: "CEFFY" plates, $600
2: brand new set of weathershilds still in packaging, $120 delivered
3: autech front bar, this is only an enquirey at the moment as i dont realy wana sell it but throw me some offers
weathersheilds are the only thing that will be posted, others are pick up
https://www.sau.com.au/forums/topic/332207-plates-weathersheilds-autech-bar/
Jason!
STOP WHORING PARTS!!!
IVE BEEN WANTING WEATHER SHIELDS FOR YEARS!!!! :)
PLEASE can you let me have these??
if you let me buy these then you can have your reo bar + aircon compressor for free.. im not kidding!
i'll copy pasta this to your inbox in case you accidentally buy these
PLEASE do me this solid i REALLY want these!!!
hey guys these parts are off my wreck.
wheather strips sold. also wrecking car. all of the running gear not for sale got all the interior minus center consol. got 4 point cage, wing, front and rear wipers one late model rear light (right hand side) right hand doors are fine all the glass is fine except the windscreen and front left window. txt 0422373612 for parts and prices.
cheers Andrew
So why can't you just tell us where we can buy new ones ?
Did you get them from Nissan? don't even want to know how much, just WHERE :worship:
Reason I ask is I am keen to know if they're still available to buy from Nissan at all.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
