Hey guys well we have been working on this R35 for some months now and we have finally got everything installed, the project was always going to be done in installments however i thought i would just share some summery pics with you and some data on the different Horsepower vs the mods done. The car has been to the track twice during the mods with times dropping on each occasion. To date its best time is 56.1 on the Queensland Raceway sprint track Not to bad for a car with standard turbos and standard ecu's at the time. Since then we have installed the F-con V-pro ecu and the power gains have been quite good however the torque gains have been excellent, this is due to the Valcon Variable cam timing ecu that comes with the R35 control system package. The other mods that have been installed include The HKS Gt600 kit which includes more stable actuators for the turbos, New colder heat range spark plug, hard piping kit, HKS blow off valves, 2 High volume Fuel pumps, Adjustable Fuel pressure regulator, Full Racing down pipes with mufflerless centre pipe. Hard piping kit and a rear GT600 finisher panel. The customer also ordered HKS intercoolers which comes with an unbelievable carbon ducting system, A DCT transmission cooler which for all of you that own one of these is a must. And the full Titanium Rear exhaust. All this Married together has yielded awesome from standard.
I guess i will let the picture do the talking this is just a few and if you want more of a particular part let me know and i will post them up.
Uploaded with ImageShack.us
Now for some picture of the Exhaust system, you can also see the DCT transmission cooler system running neatly under the car with its solid Alloy lines and braided hose.
And finally the R35 full control system this comes with a special R35 spec F-Con V pro Ecu and a Valcon Variable cam timing controller Together they maximize power and torque.
I will post up all the comparison dyno graphs very soon so you can all see the gains in power.
If you have any question in regards to any parts in this build dont hesitate to contact us
(07) 3356 9401
info@gtautogarage.com.au
cheers dave
  handbrake said:
damn that HKS gear looks nice. the intercooler and carbon ducting combination is a work of art
is Drew coming out to QR on the 23rd?
I would love to see this car go for the GT800 upgrade!
Hopefully, not to sure he has been away for work. Yes i wanna see the gt800 kit too..
would love to see yours and his beating the Porsche's.
dave
Hi Dave,
Kind of offtopic question but regarding the HKS F Con V Pro's, I have one of these ecu's and am looking at installing in my series 1 s14 silvia.
I don't have the correct loom for my car or any sensors and all of the looms I could find for sale are piggyback type designed for all f con models (FCON V PRO, FCON IS etc).
Is it correct that if you run as a piggyback with the standard ECU you can still run MAF setup?
Can you purchase a standalone type loom or is the piggback loom also used in this application just without connecting the standard ecu?
I realise running standalone would require me to run the 3 Bar map sensor and I would probably run the optional temp sensor as well in this configuration.
Cheers
Edited by «Cyph3r»
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
