After reading right through GT's and Joey's E85 threads i have become inspired to make something more adaptable to everyday streeters wanting to run this Flex Fuel stuff caltex is bringing out.
I'm getting quite keen on this caltex bringing Flex Fuel to the ACT :)
so much infact that I'm looking at doing a CarPc type thing so i can change fuel Maps from the sterio/GPS/Touchscreen...
Here is a one-click program i just wrote to change maps on the fly...
This program automatically opens up NIStune -> Opens the correct map in NIStune -> connects to the consult -> Updates the Map and Burns it to the ECU -> Then returns to the desktop... All in about 5 seconds :)
Obviously you need to have the maps pre-tuned for each blend
I think this is a pretty good option for us running NIStune to take the benifets of Pump Exx fuel...
for those that don't want to have a laptop in the car the whole time that is ;)
I also have plans to investigate the Ethanol sensors and make an auto adjusting map.
This won't be in real time (like the flex fuel cars) but after you fill up run the program and it'll get the Ethanol content and change the map to suit the current blend in the tank...
But one step at a time!
So if anyone can see any major flaws in my plan please speak up, as I'm keen to get something like this availiable for everyday streeters wanting to run Flex Fuel
Cheers
I have that already with the dip switches on the unit but I can only switch in one fuel and one timing map. This car pc idea is a lot more practical than lugging a laptop around in the boot like most of us do.
Fair enough, Not sure how you would get around the panel that asks "do you want to communicate with the blah blah blah, prob just as easy to load the EMU software onto thew car pc and open it at the servo and load up the map you want and drive away.
this is a great idea, hopefully something can be made easily so that i could run e85 for track days etc and PULP 98 when just getting around town.
i've been wanting to run e85 but the worst part in SA is that its only available from one servo.
so if i wanted to take my car for a long drive away from the servo i would have to plan ahead and make sure i could get there and back on one tank.
it'd be handy if i could just switch to a different tune and run e85 only when i want to really make some great power
Good to see some interest in it :)
I'll be building my CarPc up over the next month or so and the fuel isn't avaliable untill somewhere near october, so untill then i won't be able to work out all the bugs and teething problems that'll come with it no doubt...
Also those people running a CarPc, whats it like with booting up times and stuff?
I'll be running mine as my sterio so i ain't gonna want to wait 5mins till it starts playing.
If anybody has gotten around this with another battery and a relay setup so that the computer never turns off let me know.
Also for the EMU stuff, if it runs off windows then it's possible to write a program to automatically connect and change maps.
That's all this program does... just takes out the human interaction and presses the correct buttons in nistune on its own... Basically...
So any automation in windows is possible, as long as the software to talk to the EMU is installed
Nothing special as far as windows install goes, haven't leaned the installation out at all.
Boots up in about 30 secs.
If you get a decent PSU and wire it up properly, the PC will commence booting as soon as the the key gets to the ACC position and won't reboot while cranking.
I also use mine for music but I cbf wiring the PC to an amp so just run RCA out from the front of my CarPC case to the Aux jack on my deck.
  • 2 months later...
Update.
Got my CarPc up and running. with the nistune software on it.
I also now have a nice PULP98 map and an e70 map.
Over the next few weeks when I have time I'll be finishing off the programming and scripting to get the "one button fuel map change" going.
I will make up a "Mid Map" where i use mostly the PULP98 timing map, but adjust the fuel to suit a 50-50ish mix for those pesky occasions where you're at the coast with half a tank of fuel and not enough to get home and no one sells the good stuff...
Also looking at doing a one button "lean by 1 AFR" and "richen by 1 AFR"
Failing somehow integrating the ehtanol content sensor into NIStune, i reckon this'll be about the best way to make the most out of the e-flex and e85!
I'll get some pics up soon :blink:
Wait till you hear porn through the stereo.. strangely seems to have some serious bass to it :P
P.S. good work on the NIStune front, keen to see results :D
Edited by bubba
Love it, I've had my customers switch images via hardware but it relies on the driver to have some idea rather than be asked. NICE WORK!!
Has Matt added this code to his latest beta?
Nar mate. I'm working on this as a stand alone from NIStune.
Although i would like to work with matt, i love what he's doing with these NIStunes, this is more of a script than more software. The script/stand alone program will open up nistune and automatically use nistune's ability to change the maps in the car.
you have to have the maps ready avaliable on the pc and it'll just grab which ever one you ask it to and chuck it in the ecu, then quit and get back to your porn... lol
I'd like to see how the ethanol sensors will work with a ViPEC ECU...
Otherwise, good work Pat. Keep it up!
Fine, the link G4's have no issue so its carbon copy wont have an issue.
Not enough room on the nistune boards to run multiple maps, wish there was as we do a fair bit of nitrous and e85 (2-3 a week).
Matt and peter explained exactly why not a few years back but i forgot...
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
