Hey guys. Its time to get rid of some stuff out of the garage. All items are located in Georges Hall, Sydney (Near Bankstown) apart from the N1 block which is at Beverly Hills, Sydney. Buyer pays postage. Pickup is preffered.
Nismo fuel pressure regulator. Like new. Was on my car for about 10,000 kms. I only changed it because I went to a duel entry fuel rail and a sard reg. $110
N1 (24U) Block. I was going to use this for a build but I bought my car with a GT block in it. I will never use it. $1990
Greddy water pump pully. Aluminium, pretty blue and very light. I bought the set so I have used the alt and PS pulleys but I am using the big ATi harmonic balancer which needs a smaller pulley $50
Standard second hand RB26 coils. Done about 80,000 kms $40
Rays blue valves and valve caps. I got these when I bought my TE37’s. I don’t like the blue, would rather the black. Never been used. $40
Heat wrap. 4 rolls at 1 inch by what looks like 15 metres. It could be 25metres but its all sealed in its plastic and i dont want to unroll it to measure it. These came with the Tomei Expreme manifolds. $70
OS Giken 5th gear. Brand new. When I rebuilt my box I bought the 5 speed but I decided to stick with the standard ratio. $290
Standard OEM 5 speed centre plate. Came out of a box that was 11,000 kms old. $20
Second hand Tomei manifolds. There are a few cracks in them. Might be worth getting them fixed up and throw them on. Done 15,000 kms. $50
Goodridge braided brake lines. ADR Approved. FRONTS ONLY! Bought these thinking they would replace the factory metal line. I went 345mm rotors up the front and it was easier just to get a line that went the whole way. Never been used. $100
Copper radiator. Its roughly 45mm thick. Works very well. On the track with 370 rwkw water temps got to about 85. Barely moved. Has a very small leak where the drain plug is. Easily fixed. $100
https://www.sau.com.au/forums/topic/332222-gtr-parts-new-and-second-hand/
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
