Here's the problem:
I got a letter in the mail today from the EPA stating that a police officer had lodged a report against my car because it was "excessively noisy". It goes on to say that I must take the car to an Approved Vehicle Noise Tester to determine whether it complies with the Environment Protection Vehicle Emissions Regulations. (There is a list of 24 Noise Testers across Victoria on the last page of the defect notice). After I obtain a Certificate of Compliance from the Noise Tester (asssuming I pass!), I must lodge it with the EPA by 20th February. It also says that it was not necessary to stop my vehicle in order for the police to file the report! All they needed was my rego.
There is some information contained in the letter about the noise tests.
"Maximum noise levels for stationary vehicles not to exceed 90 dB(A) for a passenger vehicle manufactured after 1st November 1983" (I've paraphrased slightly.)
So my questions are:
- What in particular do the noise tests involve? I have read elsewhere on the forum that you need to rev your car to a certain level, but how is this level determined? By engine capacity? Whatever the case, I am certain that my car will fail because it is f***ing loud! in which case...
- What are the options I can take prior to the test to ensure that I pass?
- Also (this part is mainly a whinge), isn't this stuff covered by a roadworthy and/or Certificate of Compliance? I'm talking about the Certificate of Compliance you get when you first import a car into the country. When I first registered my car last year after importing it (and getting my engineer's CoC), I was surprised that neither the engineer or Vic Roads did not say anything about the noise. I had it registered at the Burwood Vic Roads who are notorious for checking EVERYTHING, so I am a little surprised that nothing was mentioned at all about the excessive exhaust noise level. (As a side note, avoid getting your car registered at the Burwood Vic Roads, this is a tip from Dean at Ultimate Performance Imports in Moorabbin. The guy wouldn't pass my car because it was ONE CENTIMETRE too low! Plus he had this measuring stick thing which was supposed to fit under the car to test the height and he was banging it like nothing else against the exhaust tubing.)
Any comments or suggestions are welcome.
https://www.sau.com.au/forums/topic/33226-epa-noise-defect-notice/
i got my epa in the mail a couple of weeks ago and failed my test(got 103db's).. put my stock cat back system on with cable ties(took a whole 10mins) and went back for the retest and they didnt even turn my car on.. just payed them $20 and they gave me a thing to send to the epa.. if you want to come borrow my stock cat back just let me know as iv allready put my 3" back on.. im in mentone
Not too steal the show, though I myself was looking at getting a cat-back soon for a R32 GTS-t. Being the brand-name guy I am, the APEXi N1 was looking great, though it exceeds the 90db limit. I was thinking of getting the Super Silencer fitted (welded), to reduce the noise, but thought I might find another good brand-name exhaust that works just as well and produces less noise.
Any ideas? 5Zigen? HKS? It's gotta be less than $1500.
Exactly the kind of Anti-import-Nazi stupid sh!t that everyones probably had to put up with at some stage... I bet he drives a Holden. (no offence to the 2 cool holden drivers on SAU)
He probably would've cut his stupid measuring stick down had an HQ been too low.
Thanks for the ideas everyone. I ended up calling William this morning who works with Gerald at Ice Performance. He was fantastic, told me to come right over even though it was his day off (he lives around the corner from me) and had a look at the car, fixed my boost gauge for free while he was at it! He knows one of the guys at the approved noise tester in Cheltenham, it's called Exhaust City on Park Road. William will take my car there first thing Monday and the dude will weld on a silencer and give me the certificate.
SKYL9 I was just about to ask where you got yours done. Good to know I'm taking it to the right place! I plan to get the silencer put on, get the certificate, then take it off again. :(
Well if the exhaust still sounds ok with the silencer then I might keep it on to keep the cops off my back, but I really like the sound at the moment, I don't want to lose my lovely exhaust note :)
Its no biggie.. you just take it to an approved tester.. give them 15 minutes and they'll do the required test and tell you want it read at and whether you pass or fail. If you "fail" you just get whatever modified and come back and try again.
1. Its a b.s. law and just comes from the officers "thoughts" of whether it is actually too loud or not. As he doesn't use any meter he just makes it up on the spot.
2. Its perfectly possible to pass with an aftermarket exhaust.. I passed at 89db with a full dump system, highflow cat and Super Dragger II catback. Most won't though, true.
3. Its 3/4 of the max rev range, so around 5200rpm for an R33
4. You don't have to send it to the EPA, just take it a testing station, and they forward it on when it passes and its all done. The test is around $30
5. Here is the list of testers.. just rock up to one http://www.epa.vic.gov.au/Noise/testers.asp
6. Please do a search in future, all this has been coverd COUNTLESS times as most people have been there one time or another
Re: 3/4 of rev range...
Do they take this from the tacho? If so - they're going to test me at 7500rpm! That's just a little unfair as I NEVER go that hard in suburbia - hell, I'm speeding in reverse at 7500!
Also - nearly finished my letter of complaint. The 'excessive' noise thing is a beauty. My car may be louder than a Daewoo - but it sure isn't excessive.
While its meant to be standard, he did mine at 5200?? there is a list of testing guidelines out there which list every little in and out.. they're out there (and on here) somewhere.
Its different for GTR though james so don't stress too much .. i remember at McLeod them telling me it was something else for GTR, but i forget what it was sorry.
The testing is done at 75% of where the car makes its maximum horsepower.
GTS-T's make maximum hp at 6400 rpm so they are tested at 4800 rpm.
GTR's make maximum hp at 6800rpm and they are tested at 5100 rpm.
Obviously when you modify your car with bigger cams and turbos etc. the point where you develop maximum hp on the rev range changes as well, luckily they don't get that anal and go with the factory figures.
The tester generally uses a multimeter to read the revs and verify your tachometer reading.
The microphone is placed at half a meter distance and 45 degree angle to the rear muffler.
consider yourself lucky i actually had to go to the epa site in macloed and i live in frankston. It was damn far. I passed with 85dB on a cat back 3.5 inch stainless kakimoto system. I also got a high powered vehicle fine on the way back for my troubles. Blardy cops. I eventually got off the high powered fine tho. but still pretty harsh after serving and passing an EPA summons.
with all these sound issues, it would be interesting to gather data of what exhaust system has been tested at which db...
so anyone else who's got their exhaust tested, maybe can post their db result and exhaust brand, and if it is cat back, turbo back or dump back, etc...
The thing which gives me the shits about this is, when you are sitting at a caffe and you can hear cars going by, yes skylines supras are louder than a pulsar or camry but they are nowhere near as loud as some hyundi's i hear which have aftermarket exhausts, which i am sure make the car louder than if they had no exhaust at all, actually v8 holden's aren't exactly quite either.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
