more info? lack of power may be rich and retard or an air leak.. air leak may explain why its running like shit and stalling.. car runs rich when cold partly countering the fact its getting more air under vacuum.. when it warms up its still getting more air but less fuel and stalls.. just a stab in the dark with the limited info u gave :/
Jarrod
Jarrod
can only give what i know has power cold and warm some times when warm and you put your foot down it will take off then all of a sudden its like pulling a freight train
and 2 as i dont have RPMs yet it is like it idles as normal then drops to all most still then gose back up and dose it agen some times it will stall out and some times it wont if you hold the revs up say 1000-1500RPM it will still do it
what did you disconnect? the connection that goes to the temperature sensor? your theory has a few holes in it.. as your assuming that with the sensor disconnected, the car would think it was cold? the car may just run the car like its hot without the sensor, plus there is two temperature sensors.
Its more than likely an air leak, ive seen this before a few times with friends cars that swear they have no air leaks and have checked it with air compressors etc..and months later we end up finding a air leak in some remote location, like at the carbon canister, once one of the runners had a crack in it at the bottom, couldnt even get your hand down there to see etc..
If its not a air leak theres a small chance it may be a dying fuel pump or an electrical issue, but more often than not its an air leak =/
Jarrod
Jarrod
fuel pump is brand new (a R31 intank one) i was told it will be enough??? in the next 3 mounths or so i'll be getting a 040 pump
when i wiried in the engine i solded all the joints
there is a earth on the alt that is held on with a 8mm can that make any difference if it in not on???
can i spray WD40 over all air hose to fined a air leak?
