Hey guys,
I'm looking at upgrading the interior of my 32gtr apart from the steering wheel gear knob and seats....can u guys post some pics of some example of some how you've done your interior or the best examples youve seen. Not looking to overdo anythin...dont want it like a show car just practical. Eg looking to change to carbon fibre pieces maybe, new headunit mayb gauges, gear boot, hand brake etc.
https://www.sau.com.au/forums/topic/332305-r32gtr-interior/
Hey Mate,
if your doing a interior in my opinion your better of opening your mind to more different cars, seeing what mods they've done and then putting the ideas from that interior and try and mod them to fit your R32 after all, i had a good look on google images and other forums etc, and couldn't find much on this sort of topic
So just look at all sorts of cars then think about how you could do that on your R32
https://www.sau.com.au/forums/topic/332305-r32gtr-interior/#findComment-5397651
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
