central locking cant be taken off the circuit board in the control box that chef_stagea mentioned, no need to unplug it or cut any wires off it though. everything else is pritty easy to find, lock/unlock indication tap into the hazard switch, figure out your immobilisation points, etc.
when i rang justcar they said that it was fine for me to do the install as long as the alarm met the australian standards. e.g 3 point immobiliser, black wiring.
Edited by QWK32
Sorry i made a typo, i meant to say it "can" be taken from the control box on the passenger side.
I havent done the job recently but do remeber what to do, it is a negative trigger off the C/B. I'll forward you a pm i did up for another user on where the points are.
  • 5 months later...
Could you pm me the same info?
Cheers
Justin
just car said mine had to be professionally installed
I have the white box on the passenger side, earthing out the purple/grey wires locks and unlocks all the doors except the drivers side, I can hear a relay click from the control unit on the drivers side but no effect on the lock itself=(
Is this common, does anyone know what my issue is??
Thanks
yep, thats common. and you will sit there scratching your head for hours trying to figure out why the drivers side door wont lock, i know, i wasted half a day trying to figure the door locking system out. basically the white box on the passenger side is the receiver for the keyless entry, two internal relays (lock and unlock) signal the drivers side door to lock / unlock and also trigger those same functions on the white box on the drivers side. the box on the drivers side is the central locking box, as well as doing a couple other things like dome light supervision etc.
there is a difference between central locking and keyless entry. the stagea's central locking looks for a signal from the drivers side door i.e turning a key, and then actuates the other doors. keyless entry will operate all the doors. the wires your grounding are most certainly the central locking signal wires to the drivers side box to lock / unlock all the other doors. you need to tap into the keyless entry trigger points, and that is all done internally in the passenger side box, which means soldering to a circuit board to switch the lock and unlock relays mounted on this board.
have a look at the attached PDF, its a little write up i did a while ago when i installed mine.
Stagea Door Lock Relays.pdf
  • Like 1
same as a R34. the remote side of it is an after thought. two separate systems at play there. they did the same thing with the R32 GTR and the dealer fitted alarms in them.
  • 5 years later...
On 13/08/2010 at 1:51 AM, GoldZilla said:
Check with your insurance company before you start fiddling too, some insurers won't pay up if your car is stolen and the alarm wasn't professionally installed.
How would they know?
8 hours ago, KiwiRS4T said:
They would ask you for the evidence (invoice/receipt)
Doubtful. What if my mate, an electrical engineer, installed it for free for me? They going to ask to see his degree?
What if he's dead?
  • Like 1
  • Haha 1
  • 1 year later...
Thanks this is super helpful! Seems like I am on the right track!
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
