im trying to find the stock boost for a stock r32. iv heard 10psi, 8, and 7psi. very confused. im running 10psi on my fully stock r32 but dont know if its been played with or the acutator had been changed by the previous owner. it hasnt got a boost T, boost controller anything.
Its a Gts-t r32 1993 skyline.
Thanks. :P
Edited by BenSm
https://www.sau.com.au/forums/topic/332358-stock-boost-of-r32/
i've got the notes at home straight from the nissan service manual, the actuator is rated to open at 0.80kgcm2 to 0.85kgcm2 from memory
so the average is 0.82kgcm2 which from memory is just on 12psi
ill post up the official notes from the service manual tonight
sweet, Thanks for your replies. atleast its around what im running, it spikes to 13 so i try not to put the foot down to hard when it does this. When i slowly press down the accelerator it spikes to 13 but when i go flat stick curry it site perfectly on 10psi.
Please do Paul.
Would be an interesting read coming from Nissan.
yep will do
ive got
HR32
BCNR33
ECR33
i need
ER34
BNR34
if someone has the service manals for ER34 and BNR34 can you please check and show me what it is
im lookuing for the section that show how to test and diagnaose the actuator not working
it is usually worded like;
to test the turbocharger wastegate pressure control connect a pressure vessel guage to the diaphram and blow compressed air to 0.80kgcm2 until the actuator rod beings to move.
the actuator rod must move at the minimum required pressure
mythbusters ahoy!
Use the air gun to blow compressed air approx A ~ B kgcm2 into the hose and make sure the swing valve controller rod operates.
where
HR32 - A = 0.8 and B = 0.9 kgcm2 which is 0.85kgcm2 (average) which is 12.08 psi
BNR32 A = 0.7 and B = 0.8kgmc2 which is 0.75kgcm2 (average) which is 10.66 psi
ECR33 manual is 385mmhg which is 7.4446 psi
ECR33 auto is 270mmhg which is 5.220 psi
BCNR33 A = 0.79kgcm2 and B = 0.85kgc2m which is 0.82kgcm2 (average) which is 11.6 psi
if someone can find ER34/BNR34 please let me know
  • Like 1
the nissan spec manual is bang on - for HR32
Use the air gun to blow compressed air approx 0.8 ~ 0.9 kgcm/2 into the hose and make sure the swing controller rod operates
so the minimum boost on HR32 is 0.8kgcm2 which is 11.3PSI and the high end of the minimum is 0.90kgcm2 which is 12.8PSI
so anywhere within those specs is acceptable to nissan and the factory specs. this is why i quote it as 12psi, as its the average in the middle
mythbusters ahoy!
where
Thanks a lot Paul!
:woot:
That confirms I was right with my conversion on my stock boost pressure.
yep that's prefect
find the section that shows you how to pull apart the turbocharger
in theree will be a secion on how to test the std actuator, and what pressure it requires to make it open
this is the minimum boost
how do you figure stock r32 boost is 10psi if the nissan service manual says the minimum opening pressure for the actuator is 11.3 psi?
i just don't get it
id say if you are seeing 10 psi
your actuator is faulty
you have a pressure leak
inefficient intercooler
inaccurate guage
or guess reading
it is important to note, that the service manual says that applying 11.3 psi pressure at the actuator will make it move and thus open the wastegate
it does NOT specify that you will get 11.3 psi at the back of the plenum, so if you see less boost than 11.3 and you consider this "std boost" then you have a pressure drop
yep that's prefect
Ok, I had a read through, turns out it is the Service Manual which you have on your website.
Seems the "Workshop Manual", ppl claim on the internet is the Service Manual...
I can't seem to find anything on how much boost pressure it runs...
That's probably why your asking to... ;)
Damn annoying.
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
