Its actually very easy.
After putting two through compliance, i can now do it in a few mins.
sorry haven't done it in a couple of years, but off the top of my head
1. Check how grill is attached. There are 4 tabs in each corner of the chrome grill with little screws. These are actually clips so just half a turn and they should pop out. Hang on, maybe there's only two. One on each side.
2. Underneath the car, you will have to unscrew the underside dust/dirt cover which i'm pretty sure is connected to the bottom of the front bumper. There's a few screws here, i think around 6-8. make sure its the dust cover you're unscrewing as these screws are near the front lip screws. (Made that mistake once :P
3. There are 2 screws on each side of the front bumper near the blinkers. Easiest way is from the wheel well. Turn steering wheel to the left and do the right side, then turn to right and do the left side
Move the wheel arch covers out of the way and you'll see them pretty easily. Before you unscrew these, disconnect the front blinkers. Usually just a half turn and they'll pop out.
Also before you unscrew the side screws near the blinkers have someone hold the bumper or prop it up, as these 2 screws on each side are all that hold it.
and that should be it.
If it gets caught anywhere, don't force it. Have a look to see if I may have missed a screw.
2. Underneath the car, you will have to unscrew the underside dust/dirt cover which i'm pretty sure is connected to the bottom of the front bumper. There's a few screws here, i think around 6-8. make sure its the dust cover you're unscrewing as these screws are near the front lip screws. (Made that mistake once :woot:
I have removed mine and you dont need to remove the grill from the bar, just remove all fasteners that hold the grill and bar to the car,.
This is the same for my mates M35 Stag.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
