So I've recently moved to Revesby from the St George area, and using the M5 from the River Rd Revesby it took precisely 1 hour and 40 minutes to get to work, which is f**king ridiculous compared to the 40-50 min drive it usually takes me. I'm going to try Centenary Dr tomorrow but I think its going to be shitfight as well. Anyone know any handy shortcuts to bypass the major roads (carparks)? I need to be at work by 8am.
Cheers!
https://www.sau.com.au/forums/topic/332385-revesby-to-lane-cove/
Used to live in Penshurst and drive to Lane Cove once a week.
Way I used to go was down King Georges/Centenary Drive/Church St and then take the exit and turn right when you hit Victoria Road.
Keep going all the way down and take the exit to Lane Cove when you get to the Gladesville Bridge.
From Victoria Road onwards it was a pretty sweet run especially at that time in the morning, it used to take me about an hour.
Nah nowhere near there. If you're going up Homebush Bay Drive, you go straight over Parramatta Road. You need to keep going past Rhodes, past the bridge on Concord Road/Church St and then just before you reach Top Ryde there is an overpass for Victoria Rd where you have to take the exit on the left and then turn right onto Victoria Road.
From Revesby I guess you have to take Stacey St and then go down Liverpool Road to get to King Georges Rd first.
Ok, so I'm really bored at work...
Here you go:-
Driving directions to Lane Cove NSW
29.3 km – about 58 mins
Via Chapel Rd Sth, Church St, Victoria Rd - remove all
Revesby NSW
1. Head north on The River Road towards Flood Ave
1.5 km
2. Turn right at Canterbury Rd
900 m
3. Slight left at Chapel Rd Sth
1.2 km
4. Turn right at Macauley Ave
700 m
5. Turn left at Stacey St
2.2 km
6. Turn right at Hume Hwy
3.4 km
7. Exit onto Centenary Dr
3.4 km
8. Continue onto Homebush Bay Dr
3.4 km
9. Continue onto Concord Rd
1.7 km
10. Continue onto Church St
750 m
11. Take the exit towards Victoria Rd
240 m
12. Turn right at Victoria Rd
5.2 km
13. Take the ramp on the right onto Burns Bay Rd(on approach to Gladesville Bridge)
3.0 km
14. Turn right to stay on Burns Bay Rd
190 m
15. Slight right to stay on Burns Bay Rd
Go through 1 roundabout
1.5 km
Lane Cove NSW
you could crank a route similar to this-
http://maps.google.com.au/maps?f=d&sou...528374&z=12
king georges, roberts rd, centenary drv through homebush - then victoria rd exit when you hit ryde
edit: doh beaten
I would LOVE to own a bike, but I'm fairly convinced I would get killed on it, so I'd prefer to be late then dead, even though it would be a lot of fun on the way!
Anyway I found that way pretty good on the way home, but on the way to work the Hume Hway/Centenary Dr was clogged until the M4, is there a way to bypass that?
;) EARTH will do the trick, failing that use the UBD
Welcome to revesby :worship:
best way to get there in the morning would be to go thru punchbowl rd/or canterbury rd then onto roberts rd and onwards to homebush/lanecove rd. i have never actually done it that way before.. or ever had to get there at that time.
get a job closer!
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
