  • Replies 61
some people aren't just after the peak power output, but rather a quick spooling turbo for the streets with a fatter power band. its really upto the individual
I agree although would you be happy with a 20rwkw (peak) increase (over the standard r33 turbo) after spending $2,500 on an aftermarket turbo?
Edit: ...and running 17psi vs 12psi.
I think i'd be "over" 20rwkw after about 6mths and it would be a waste of $2,500 to me (personally).
I wonder what the average power is tho with that hi-flow.
Cheers Benm,
Thanks for the kind words guys
Robo: I was on the same mental track as you. Pulled the turbo off to reviel a stock unit. Just goes to show what they can do. I found strangly enough installing a new fuel pump made the most difference power(044) .....may be the key. It was last dynoed @ 218rwkw@ 15psi before the run. I did however run octane booster and dial in an extra 2 degrees advance for the night. My 2.2 was due to severe axle tramp. I have since installed solid bushes and am now running 18" 255 Nitto Extreme ZR Tyres.
Bigcarl: I was running 17" 255 @ 18psi Bridgestone Regano's (jap)
Robo: On the Dyno the fuel supply was fine , however I found on on road testing if I kept my foot into it through the first three gears it was start running out of fuel. On the dyno the car is only ramped in fourth and so the issue wasn't apparent. 4th and 5th had a noticable difference. Have you noticed if you just sit in say third then dump it it feels faster than getting to third after thrashing 1st and 2nd.... (keeping in mind constant intercooler temps)
I spoke to the guys from GCG today at Drag Combat (WSID) and it was $1,900 for either a 450hp or 500hp (same price) + $400 for something else (they dont have any "ready built") so you have to drop ur turbo off and it takes them 2 days to hiflow it.
