hey guys ive installed my intake plenum but have no idea how to install the top hose outlet on the plenum. cant weld it because of the different types of material. is there a special glue of some sort that you use to put it in. or what have you used?
thanks
https://www.sau.com.au/forums/topic/332411-rb25-greddy-copy-inlet/
top hose outlet? which one are you talking about?
are you talking about the bleed nipple?
no where the actual top hose from the radiator clamps onto the inlet, mine didnt come welded on or anything but i got the littloe pipe that fits into the hole as pictured below
Edited by r33skyhigh
I had a kit that came with my plenum. Included all the bolts, fittings etc. It had the fitting for the radiator hose. Now i got mine off someone else but he bought it from autobarn and they sold him the kit as well.... So maybe give autobarn a go
Its basically just a press fitting that will just tap in, seal it with some loctite or similar when you put it in
Im betting autobarn will have it it or will be able to get it in for you. If not I think (but not 100% sure) that the genuine Greedy plenums are the same so might be able to get the fitting through nengun or something in the option parts?
EDIT: Just checked nengun and greenline, doesnt look like you can get the fitting for the Greedy plenums, Try autobarn
Edited by 89CAL
yeah i got the fitting its just not on. ill try tapping it in see what happens shouldve done it before i put everything else on...
should be alright, might have to remove the throttle body at the worst. Using a sealing compound when you knock it in for a good seal :D
smear it with liquid gasket and shove it in, hit it with a bit of wood for it to squish in.
I doubt any shavings will come off as your not shaving anything. If they do come off its in your water not your oil which is no biggie.
oh, you said "tapping" which is tapping a new thread, when you do this, quite a bit of shavings come out.
but i can see in the pic, just put a rag in the hole and do ur busness, pull the rag out, should catch anything that fell in ???
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
