Yeah so haven't been here in a while.
Also haven't driven the GTR for about 3 months. Too many d!ckheads with them, too much attention and stress. Does about 1000kms a year.
Should I sell it...? and if so, how to put a value on it??
hi to all who I haven't seen in a while too :blink:
https://www.sau.com.au/forums/topic/332419-been-a-while-should-i-sell-the-gtr/
Marcus!!! How you been? long time no see.
Welcome to the club, although I've done around 600kms in 2 years.... :worship:
You have one of the cleanest, well modded 32 GT-R's around, and it's an Aussie delivered one too!!!
Worth good dollars that's for sure....
You'd have to sell it through Shannons or similar type of Prestige Auction house Marcus.
You won't get a good price otherwise. I think one went for around 40-45k recently that way (ADM 32R)
Oh, and come out and say hi once in a while you rude bastard :)
sorry ash, jack, dan, al et al... :woot:
I'll visit more often!
I still love driving it but it's less and less frequent. Also there is a x-fer case noise that needs to be looked at... so maintenance/insurance/rego is a stack and it doesn't much get used.
Thinking of taking it out on w/end for a blast... cousin just got a 3.8 GT3 so want to see how the old girl goes up against it
Keep it mate. Things ebb and flow, and when things slow down having that car to enjoy or go for drives in would be pretty awesome. Its a low key thing that would pass 99% of inspections as the thing is pretty stock. You seem to be doing plenty of travel with work
you really get hassled and stress about driving it?
I drive mine nearly every day and nobody even bats an eyelid... I pretty much get ignored and I like it that way... IMO getting rid of the personalised plates helped as well
that said I don't drive Fri Sat night and try to avoid the 'hotspots'
I just spent a packet traveling so don't have the coin to track it at the moment but I still enjoy driving it... even at the speed limit;)
I say keep it... if yours is the one I'm thinking about you put a heap of time and effort into getting it right... unless your desperate for the cash tuck it away until you get motivated again... my 2c
I'm with NickR33 on this one.
hi to all who I haven't seen in a while too ;)
I hope you are not letting these little things annoy you to the point of selling your car?
I drive mine everyday to and from work.. sees about 70+ k's a day, with personalized plates and like Nick says people don't really care.. been pulled over once by Graeme on the forums here but it was pretty much for a chat :thanks:
keep it mate. if you still enjoy driving it, and can afford to keep it then just let it gather dust.
as for the limited kms i guess it all depends on where u live and the cops in your area.
i live in knox which most know is a bad area if you have an import but i do 400-500kms a week without any issues.. touch wood :)
Being an ADM GTR, I'd definitely sit on it, because the values are only going to go up and you'll be kicking yourself if you sold it too soon.
Are the price of a 32 gtr gona go up?
why..
Its really good to hear this, making me want to keep my car even more!! hahaa sik.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
