Hey
Recently had my turbo highflowed via hypergear n the responce is awsome,
he did advise to change the standard intake pipe which is rubber to metal (and larger diameter)
has anyone done this? and could they point me in the right direction about where to buy one?
any help would be great,
Cheers
https://www.sau.com.au/forums/topic/332421-intake-pipe-from-pod-turbo/
be careful if you have a nice shiny straight peiece of metal as the intake ducting
the standard intake pipe has accordian style bends in it to avoid afm signal reversion
if you put in a nice perfect straight piece of metal it will cause reversion of the AFm signal and make the car run like ass
good advice, i was planning on moving the AFM to the cold side of the cooler piping, just b4 the blowoff valve
so pretty much, pod-> pipe-> turbo
guess size dnt matter cos i'll have to use some silicon hose to narrow it down into the turbo?
cheers all
just keep the standard intake pipe with the afm in the standard position. if it sucks closed then put a small piece of exhaust pipe in the middle of it, theres a guide on here.
you do not need a bigger intake pipe with a highflow
nothing at all dodgy about it. you cut the stocker pipe, put an offcut of exhaust pipe in there and hose clamp both parts of the intake pipe to it.
intake pipe wont change what airflow the afm maxxes out at, once again stocker would actually be better than a metal pipe as it has the ribs in it to stop any reversion
yer i have a metal intake pipe and also dont have any issues but i made sure it was nice and long with a decent bend in it. but the only reason i made one was to suit the 4" intake on my turbo. if you have a small turbo inlet theres no reason to use a metal pipe
Get a metal intake pipe and relocate AFM and BOV. If you are concert about cop problems dyno tune your car with 3inch metal pipe and pod before putting the REV210 metal sleeved stock intake pipe back on. Stao explained side affects of it into detail with dynosheet comparasm and users comment in his tread as well as installation notes on AFM and BOV relocation. Have a read in this thread. from memory its in page 39 & 43.
Edited by kwickr33
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
