Hey guys
Item:
5 Speed manual gearbox, came out of my r32 GTS-T rb20det 2 door
Genuine K's: 86,000K's
Excellent condition!
Price: WAS $800 NOW $400ono
Can Frieght at your expense
Item:
Set of 4 rims with brand new tyres, 1 tyre needs to be replaced. All 4 caps are there. They are 4 or 5 stud wheels.
17x7 Sparco Wheels
Rears 235/45 ZR 17
Fronts 215/45 R 17
Price: WAS $800 NOW $600ono
Item:
Mint condition drivers side skirt for 2 door $80
Item:
Mint condition manual tail shaft for 2 door $140 or take it with the gearbox for $500
Item:
R32 GTS-t Front rotors and 4 pot callipers
Genuine 86,000K's
Excellent condition
Price: WAS $400 NOW $250ono
Item:
R32 GTS-t RB20det
Factory Dump Pipe to Cat, 2 piece.
Excellent condition
Price: WAS $200 NOW $170ono
All prices are neg. Make an offer on all parts. Can also frieght any parts at your expense
If there is any parts you need from an Imported 1994 R32 GTS-t 2 Door Coupe Message me and see if I have it!
Located: Victoria
Contact details:
PM Me
[email protected]
Txt only 0448 644 653
Pics:
https://www.sau.com.au/forums/topic/332422-parts-for-sale/
