Hey guys thought this would make a pritty cool thread, after all im sure there is atleast one car out there in some movie that you wish you yourself could drive. Some of the rides although in many films the cars they use are nuggets, they do look extremely beasty and many people do envy them.
So i thought idd start off this thread by giving my favourite car of all time even though the film is decently old now.
R34 from ' 2 Fast 2 Furious ' the car which sums up the start of the movie, until it gets run into a wall :)
Hope to hear back and see some of your favourite cars up on here
https://www.sau.com.au/forums/topic/332485-favourite-cars-from-movies/
  • Replies 44
Pretty much anything in Jackie Chans 'Thunderbolt', great movie although maybe not the FTO :)
Nissan Skyline R34 GTR from Fast & Furious 4.
Nissan Skyline R32 GTR and Mazda RX7 FC from Initial D.
Mazda RX7 FD from Initial D.
Mazda RX7 FD Veilside Fortune model.
Nissan 350Z Veilside Fortune model.
Toyota AE86 Trueno from Initial D.
Lamborghini Countach from Cannon Ball Fever.
The Mach 5 from Speed Racer.
The Batmobile.
Bruce Wayne's Lamborghini Murcielago.
Honda NSX from Pulp Fiction.
Will Smith's Porsche 911 Turbo 3.6 (964) from Bad Boys.
Will Smith's Ferrari 550 Maranello.
The original Eleanor from the 1973 H.B. Halicki Classic. "Gone in Sixty Seconds"
Mach 1 Ford Mustang
No computer graphics, no stuntmen. 45 minute car chase. RIP H.B. Halicki, who not surprisingly, died filming an action movie.
There was only one Eleanor for the filming of the movie, which was low budget. Here it is today.
A real movie star.
Stallone's 1950 Mercury from Cobra. Looks different cause it was repainted for gone in 60 seconds.
Now
Original
Some things look better as they get older Bobby.
I'm a poor example. I was a '49 baby - and look at me now :D
+1 for Stallone's 1950 Mercury.
Also, the white 1970 dodge challanger from vanishing point/death proof and the audio slave "show me how to live" video.
http://il.youtube.com/watch?v=5v8NpGbzb2w&...feature=related
What about some of the cars from American Graphiti? The father of all car films...
Or Christine... the 1955 chev
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
