  • Replies 225
Posted Images
So I been digging through my pictures that I've put up online, finding some cool f**king pictures I've taken over the last year.
When I got my calipers sand blasted.
People whinge and moan that it's too hard to take the caliper off the knuckle, take it apart, sand it, do it the proper way.
I cringe every time I see calipers with 8 coats of paint on them, the same color paint that's all over the rotor, and half off the wheel well.
I got 8 calipers (total 16 pieces) blasted PROPERLY for a carton of Corona. It took 1 day.
The other cool pics I found was my old Laurel halfcut.
I somehow dragged that all the way out the driveway and up next to the tree by myself.
The local council left a 7 day notice on it the next day.
  • 1 month later...
  • 3 weeks later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
