Anyone know if the Autech comes out with LSD or updated swaybars?
As a standard car from the factory.
No to the sway bars....no option available from the factory.
...and the LSD....not unless it was made from an AR-X or it was optioned on when purchased!
Fulcrum now own the Selby's name, I contacted them recently about our sway bars;
1; They are 27mm front (instead of 30mm) blade adj, 20mm rear (instead of 22mm) blade adj ;) .
2; They now cost $457 (front) $418 (rear) :blink:
3; there is a 4-6 week turnaround on orders
4; After contacting Wholesale Suspension in Penrith, the price dropped to $360 (front) $340 (rear) due to the amount of business they do with Fulcrum.
I would be leaning towards trying to find someone to re-make the original bars, this might be a more cost effective way to get what we want. I'm not against anyone making a buck, but surely we can do better...
Go direct, fulcrum are Greedy Kents (look what they did to tein) and they load everything up to much. i saved shitloads going direct, id much rather line Todd Selbys pockets than graham's.
I just had custom ones made for our race car and am about to send off the BMW 750il ones to have made too.
Signature sway bars 02 95255619 price was half what you guys listed.
Ok everybody, I've had a busy morning!
On the phone with Todd Selby this morning, asked about the possibility of NM35 sway bars, he says no problem!
Result! :D
Initial pricing is $285-$310 front, depending on complexity and $260 rear. Both are as per the original sizes 30mm solid front, blade adjustable 24mm rear, blade adjustable. The adjustment will be one hole either side of the original mount point, giving three position adjustment. This pricing will change if we can get a worthwhile number of people together in the form of a multi buy.
So, what I need is an expression of GENUINE interest from those who wish to have these. Once I have numbers, I'll firm up the price with Todd and get back to you. Once the price is set, I will be asking for cash up front to go ahead, (so I'm not left holding the bag if things go wrong) if at this point, people don't come good with the funds, you will be on your own, I will not wait.
The above prices do not include freight, this will be extra. Don't worry, I'm not intending to make any money out of this, just trying to make it a bit cheaper for everyone.
Pm me with your interest, and hopefully we can get this going.
If you're not interested, please don't get caught up in the excitement, as you'll be wasting everyone's time not just mine.
Cheers, Dale.
Edited by Daleo
Can you let me know when the money would be due? I'm expressing interest, but not 100% firm yet. (I haven't got the car yet FFS.)
I would say we're probably several weeks away from needing cash. I don't want to have to wait too long though...
So everyone talks about the benefits of sway bars, how about the negatives?
Does it make the car a lot bumpier?
I've driven an x-trail and they seem to corner more stable than my arx and with less body roll, the ride is definitely less supple but not overly bumpy.
If the swaybar upgrade brings it to x-trail standards for ride quality then i dont mind... however if it starts to feel like a go kart i dont think my wife and newborn will be too impressed..
I have the swaybars + the Bilstein shocks and my wife does not think my car is too bumpy and she is not into me doing any changes to my car at all.
The Swaybars will firm it up but not so the ride becomes choppy.
What WILL.I.AM said.
Not interested in the twisty bits. But an improvement is always a worthwhile upgrade.
You can never have to much over taking power though. :D
A sway bar is more properly called an anti-roll bar. In a straight line it has virtually no effect as the left and right move in unison. When turning left or right the bar becomes twisted and it is the resistance to this twisting effect that tends to keep the car more level - so no, it won't give you a harsher ride.
WHats more important - sway bars or coilovers?
I don't know if I can answer this as you are looking for but when I got my ARX the suspension was very soft and the car was wallowing and steering from the rear when going through dips.
I replaced the sway bars (adjustable) first and this gave a couple of benefits.
1) Removed roll oversteer and made the car more secure on the road.
2) Allowed me to balance the car on the throttle better. Able to improve liftoff oversteer (ie, bring the nose back in when hitting understeer)
Hope this helps your decision.
Cheers
Andy
Cheers - thanks for that. Does installing Sway bars take away the room in the boot? Thats probably going to be the deciding factor...
nope.. all done under the car. remove the hollow factory ones and replace new ones.
Ok, what you're thinking of is a Strut Brace, This is a bar that crosses the top of the strut towers effectively tying the back of the car together.
A Sway bar (anti roll bar) is attached to the suspension UNDERNEATH the car. It is not inside the car at all.
The one difference you will notice with Anti Roll Bars is over "single wheel bumps" i.e. potholes, as the bar increases the "single wheel spring rate", due to it's extra resistance to bending. This, I actually consider a good thing, as it is extra resistance to bottoming out your suspension
Guys, please PM if you're interested, otherwise I'll just be going ahead on my own...
Edited by Daleo
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
