negative, they replace factory parts UNDER the car
youre thinking of a rear strut brace. something the M35 doesnt appear to have as an aftermarket part.
plenty of underbody bracing available!
No strut towers to bolt a strut brace onto!
Ok guys, looks like there's enough interest to justify a group buy ;) . So I'll be organising this, look out for a group buy thread, it'll have firm prices and hopefully delivery times etc.
Thanks to those who've let me know so quickly :( , and obviously, anyone else who's interested, let me know!
yeah, on this website it says they fit all 4WD models.
Thats a good thing. I think the 2WD ones have different bars and suspension.
At a guess, the 2WD would likely be V35 parts.
Ok guys, a bit of an update.
I have just been on the phone to Todd, from Signature Swaybars, we have a go for a sway bar group buy! :)
I'm hoping to get down & see him late this week, or early next week with some sample bars for him to look at (thanks bbenny) and we should have a solid price and also an idea of his lead times to manufacture. Once that's done, I'll be posting in the Group Buy section of the forum, and linking to our discussion.
Huge thanks to all you guys who've PM'ed me with your interest; you've gotten this off the ground! Now we can all benefit. :thumbsup:
And to anyone else who might be interested, you know what to do.
Cheers, Dale.
Ok, update.
I have a set of sample bars for Todd to work from now (thanks again Ben!) and was intending to get down to drop them off to him today, unfortunately, just had 2 wisdom teeth taken out and it's giving a bit more curry than I was expecting :rofl2:
So I'll be going down to drop them off tomorrow and I'm hoping I'll have the group buy up by Wed/Thurs.
Apologies for the delay, was only supposed to be having one done but you know how these things go.
Ok gents, update.
Todd has the sample bars now :ph34r: , I'm going to give him a couple of days to sort us out with a firm price, then I'm going to put up the group buy.
If you are Sydney based I'm going to try to save a bit on postage & essentially sort out a meet up to distribute the goods. If you wish to have bars freighted, Todd is happy to do this. Please PM me your postcode, and Todd will be able to give me a price for shipping.
Todd has confirmed his lead times for manufacture at 3-4 weeks, and given we appear to have the minimum requirement, I'm planning to run the group buy until mid December, which should see us delivering Bars in the 2nd week of the New Year.
Thanks everyone for your patience, more info as it comes to hand.
Obviously, if anyone else is interested, shoot me a PM, and you too can be a part of the Sway Bar goodness.
Cheers, Dale
Edited by Daleo
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
