As we do not sell them direct we will not post prices but give it a little bit of time for Dale to organise something and he will list pricing or what ever he organise in a group buy as we said before we are not here to sell direct just to offer parts needed for others to sell.
Dale will post as soon as he organises pricing and maybe an extra part or two.
:rofl2:
And yet here you are sharing your room with a tall lanky guy from Sydney
what's Scott going on about.....to much of the green shit bud!.....have not even been over to his house today.
P.S. Scott I think I left my 10mm socket at your house....can you bring it with you tomorrow!
Pricing?
Soon mate :thumbsup:
I'll be running another Group Buy in February, to line up with the projected delivery date of the new Whiteline bars
Wayne has been kind enough to give me access to his retail contacts to ensure we get the best possible deal :thumbsup: .
Wayne has also sent me a set of Heavy Duty, Adjustable Ball Links for the rear Sway Bar. This is a known area of weakness as Andy and Aaron (possibly others) have discovered.
post-61153-0-63613600-1295526435_thumb.jpg post-61153-0-17192100-1295526406_thumb.jpg
I'll be fitting these tomorrow, as I'll be doing about 1000km over the weekend. This should provide me with some good feedback and I'll be posting my thoughts and experience, along with some pics early next week. They are of a sturdy construction and have some very neat engineering features.
If all goes well, these will be offered in a Group Buy, or in conjunction with the next Sway bar Group buy.
Stay tuned, Dale.
Indeed....very interesting.......couple of thing's going to be needed in suspension for track day's...glad you guy's are working to get them happening.
........Cannot wait to go past some of the R32 and R33's and watching them scratch there head's at a wagon with 52/48 going past em!....lol.
Stay tuned, Dale.
Dale, agree that that the LINK is a weak point but it is not the weakest point. That honor goes to the MOUNT that is attached to the subframe. It is the same part as used on the Murano but it just does not like the extra stiffness.
Current sore is LINK = 1 fail.. MOUNT = 3 fails..
If we can get stronger MOUNTS made that would be of benefit provided it is not going to put more stress of the sub frame that could cause cracking.
Cheers
Andy
Cheers
Andy
Want me to look into it Andy? Are you thinking a brace or a whole new mount? I may have to repair Craigs subframe for him one day soon too.
I'll have a look tomorrow, thanks for the heads up Andy.
If it's similar to the mount in the pic I posted for the link (The Black 90deg pressed steel one), it'll be a piece of piss...
Edited by Daleo
yes, the brace is just the pressed steel one.
If someone could make a replacement that would be "awesome". It would not be complicated at all.
If you need I have a spare one at home with small cracks on both side that I can send to whoever would like to do the design.
cheers
Andy
cheers
Andy
Got some pics & measurements today, will be looking at doing some in 5mm stainless angle shortly.
Can you take a photo of where the failures occur on the mounts?
The mount is attached with 2 bolts into the sub frame. The bracket is positioned so that the the vertical edge that the mount attaches to is toward the front of the car.
I have attached a photo that shows the mount and has 2 circles drawn on it. These are the points that the mount cracks. This photo is of a cracked mount.
Cheers
Andy
Why stainless?
Freely available to me, and I like working with it.
They could just as easily be done in mild though.
Are you thinking about work hardening? I intend to put a couple of gussets in to eliminate the flexing that would be the cause of that cracking.
Edited by Daleo
Was just going to make it out of 4140 or perhaps something else but a little thicker, laser cut, 20 tonne press to right angle bend, and perhaps coin where necessary, and then zinc plate it.
I was contemplating making it out of one piece (ie not welding anything) The coining would take care of the strength, or the thickness of the material. Without measuring, the factory one looks pretty thin. The equivalent in 5mm would be strong enough as is without welding.
What grade of stainless you going to run?
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
