Slightly embarrassing update to my post about the Heavy Duty Whiteline links...:blush:
Turns out the orange covers are not a dust cover at all; they're just for protection of the joint & threads in transit...
Red faced all round for me, but they were just so neat...:spank:
As you can see, they came with neat little nylon shields to further protect the ball joint from stones, dirt etc.
post-61153-0-73962600-1295966347_thumb.jpg post-61153-0-72279400-1295966370_thumb.jpg
I removed the rifling from the centres of the shields with a scalpel, and also cut them down to 10mm so they would fit neatly over the shaft hex, and not press against the ball joint dust shield.
post-61153-0-03174400-1295966404_thumb.jpg post-61153-0-39808100-1295966429_thumb.jpg
They came with nyloc nuts, which I elected not to use; preferring to stay with the shouldered nuts used on the original links.
This decision was twofold;
1; Using the nylocs precludes the fitting of the dust shields, as you would need to put a spanner on the flats otherwise the shaft will turn as you try to do up the nyloc.
Obviously without these in place, the hex on the threads is easily accessible so the nylocs included can be used.
Details next week about a group buy on these links.
Cheers, Dale.
Cheers, Dale.
I'de still put em on, especially seeing as thats exactly where mine snapped
very interested in this GB and hopefully some sway bars when my black POS gets back on the road.
Also interested in the links and bars.
Are the links going to be sold modified?
No worries, I'm on it guys, there'll be info in the next few days ok?
Modified, as in with more solid upper mounts? If so then yes, thats my intention, if people wish to have them.thumbsup.gif
Edited by Daleo
I actually meant modified as in cut to length ( I think you mentioned cutting the bolts in your install )
Not a big deal though from the sounds of it.
Did you mean that there is a chance of getting stronger mounts fabricated as part of the group by as well?
The Links are straight fit no need to cut anything Dale cut the plastic dust covers that were not actually ment to be fitted.
The guys are looking at making a stronger mount and we will leave it to them as there are many guys here with fabricating skills and they can make a few dollars if they want and make them to suite as these will only work on the Stagea so probably not worth us making them at this stage and gives more opportunity for some one else.
We do at times make heavier mounts mainly cars like Subaru but they fit allot of models so we can mass produce them easier. If some one does them in say the stainless described they will be a great long lasting upgrade we are curious to see what ends up made!
We are still at this stage looking for a way to fabricate the front links as they are something we have not seen before and very unsual but do not look like they would work that well so we hope we can arrange something.
We will keep you informed
AFAIK the Z33 and V35 rear swaybar mounts are the same as ours.
its the front that are unique to our car, and AWD models of the G35. hmm i should check in the states for my mounts
Not quite Iain.
The Link is Z33 & V35 but the Mount is Murano. (go figure) (I am not sure if they are the same as V35 but that is logical.
I have been running the upgraded front sway bar for 2 years on my car now and have not had any problem with the front Link. The most important thing is a solution for the rear Link and Mount and sounds like you guys are all over it.
Dale, I am in for the Mount when you make them.
Cheers
Andy
G'day guyz. I just got myself an ARX 2001 yesterday. Seems like the sway bar upgrade is inevidable, so count me in if it's about sway bars, links & mounts. One question though... From previous posts and comparing stock sway bar from my mate's v35 looks like rear sway bar on my ARX is identical to v35/z350. He ordered his aftermarket one from USA for about 150 incl. delivery. My question is why people buy Selby's rear bars for almost double the price? Sorry if the matter has been discussed befor and I missed it. Cheers.
G'day Skip, Congrats on the purchase mate. The 350z bar is NOT identical. It is 12.5mm narrower each side, or 1 inch narrower overall.
This places an unnecessary side load on the already under strength ball links & upper mounts.
This is the main reason behind paying "twice as much" for a custom made component that fits the car perfectly.
Also, in comparison to a 350z, the wagon carries a significant amount of extra weight up quite high; in the form of glass & steel, and most of the bars available do not allow for that. The Selby rear and my own group buy rear bar is 24mm adj; versus 20-22mm for the 350z style bars. Several suspension specialist consulted during my group buy agreed, and felt that using a smaller rear bar, would comprise the balance of the end result.
I believe Paramour may have his Whiteline bars fitted by now, and it should be very interesting to hear his feedback, as the whiteline kit uses a quite large front bar (32mm) & a small rear.
This may have been done to keep some of the understeer bias of the std car. Set up the right way, my group buy bars will actually four wheel drift controllably and even oversteer under power out of a corner now.
Whiteline did extensive on car data testing to arrive at their numbers, so I'm sure the end result will be great.
Hopefully this answers your questions, and everyones patience with me will be rewarded this week with some group buy information.
Cheers, Dale.
Edited by Daleo
Hello,
Fitment of the Whiteline sways has been pushed to this Friday. .. will be able to post not long after. Taking the Old Pacific Highway back to Sydney. banana.gif
Dale feel free to catch up to compare if you like. .
Jules
Hello,
Jules
No worries, hope it all goes well.
Just to let you know the Only U.S sway bars we know of are just like the OE factory bar and are hollow and just pressed flat ends thus why they are cheaper it is just tube steel where as Whitline are Solid spring steel and if you look at the steel price market at the moment you will understand the cost of the raw steel let alone then has to be bent , forge the ends and add the adjustment holes then powdercoated twice as we put an extra layer of corrosion clear for countries that snow and have allot of salt on the roads and makes the powdercoat last allot longer.
Edited by Whiteline
Hey guys i just imported my 2001 m35 250t rs four , 4wd turbo etc
and omg best wagon ever
please is there any chance of a list of al parts now available for the stagea , i am looking to do a full suspension upgrade using sway bars and the links in this thread also very keen on Daleos mounts if they ever came to be
also any other info on brake upgrade kits or anything will be appreciated
Edited by Sidius
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
