They are going to buy out Todd at Signature?
Either way, it's good to have someone from a large company such as this expressing interest in us.
Thanks to Dale though, for the group buy!
No, not buying him out, he actually does all their custom workthumbsup.gif.
He's trying to move our vehicle away from being predominantly custom parts, and getting us more support.
so who is the R&D vehicle? does he want to see my well used Selby (one off) sway bars that have stood the test of 2 years under my car.. :whistling:
As previously mentioned. The only down side of going stiffer has been the subsequent failures of the Links and Mounts on the rear. The lowered suspension may also be a contributing factor to this.
the replacement ones from nissan are 350z ones like you said. they are much thicker and stronger than our piss weak grass strands.
Didn't end up getting much sleep did ya Dale...LOL
They have someone organised for the Sway Bars (is it you Paramour?); apparently they have some pretty trick gear basically for on car sway bar measurement and data logging .
I might know who's helping out with some upgraded ball links for the sway bars :whistling: as this is a known weak area.
This is just the first step in getting some pretty cool suspension & alignment products.
Cheers, Dale.
Edited by Daleo
Cheers, Dale.
Hello,
Yes it's me, Car is booked in for next Wednesday. Whiteline are very keen to assist us M35 owners. Very helpful.
Regardless of what ever view anyone has if it ends up in better options and availability for all of us M35 owners then it is a step in the right direction. I am still struggling to get screws for my roof racks (help anyone).
I will let you all know how it goes.
Jules
Hello,
Jules
I agree Jules, I spoke at length with Wayne today and he is on the same page as us.
It was an unfortunate series of events that led to our disagreement, and I'm just as keen as everyone else to see quality parts for our cars becoming available.
If it can be done by a local busines; so much the better for everyone.
Regarding you roof racks, are you talking about the ones that bolt the rack directly to the bracket on the car?
If so, i'm sure they're just an M5x 0.75 thread. This is the standard thread pitch and should be easily available.
If you can't find them, PM me your address, and I'll post you some 316 Stainless cap heads.
Cheers, Dale.
Edited by Daleo
I'd like to say thanks for your effort and persistence Dale.
Whilst I have not yet purchased the Signature swaybars that you organised, I fully intend to when the time comes and look forward to future GB's.
Much happier to buy from those that do the leg work than someone who rides coatails just to make a buck.
+1 from me for future GB.well done Dale
Hi Guys ,
Just a quick update click this link to see pictures of the R+D stagea on the hoist at our workshop and also where all our product updates are plus see any comments or followers of the stagea from around the world
My link
Dale should have some other news in the near future
Thanks.
Hello All,
Had the Stag in at Whiteline today. Had a great tour of the facility and production section. Some very switched on techs there. . Looks like much will come from this for us M35 owners. .
I will leave it up to Whiteline to tell us what they will be able to do products wise.
Once they are on my car I will let you know from a owners perspective.
Jules
Here is some pictures of the car getting sway bar fitment in raw steel master these are not obviously painted yet but may give you some idea what will be available.
We are looking at 32mm solid front and a 22mm solid rear which in fact the front bar is not much difference in deflection rates to the rear as the arms on the rear bar are so short fron the mounting point.
We tested this on our deflection testion outfit and will show the results when the bars are ready for retail .
The diameter of the bars do not always seem what we think as the lentgh of arms from mounting point and how the are mounted on the control arm or strut etc can determine how much flex from one link to another which is what stiffens the roll on the car.
It was a shock to know there was not allot of diffrence between the stock 29-30mm front hollow bar and the rear 20mm bar it was just they way they are mounted and the length of the arms on the front has made Nissan and then us make such a large bar.
We believe depending on what spring rates people end up using these sway bars will stop the '747' feel you all described and will keep neutral balance front to rear.
We also checked if 350z rear was the same and we can say so far that the sway bar was excactly the same shape but 350z bar was 25mm wider at links.The rear cradle bushes looked smaller and the rear control arms looked different than what we seen on a 350z here but that was a while ago.Diff bush looks the same but will need to fit that too check for sure we did not have time yesterday.
So this is the progress so far see the pictures below
Edited by Whiteline
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
