  • Replies 162
smartrx4, engine harness is already gone sorry.
Front calipers: SOLD (Rear still available, $150 for the pair)
Monster Tacho: SOLD
Front Wipers: SOLD
Plenty left and needs to all go!
front pipes $100
sunvisors $20 each
interior mirror $20 SOLD
interior lights $40
dash loom $100
interior carpet $70
boot carpet $60 SOLD
heaterbox/ all under dash make an offer SOLD
rb26 cam/timing belt cover $70
speedo 140,xxxk's $50
brake calipers x 4, $300 Front gone, rears available!
intercooler mesh $30
trust pod filters x 2, $80
monster tacho with shift light $50 SOLD
steering wheel $50
GTR fuel pump exc. working order $100
glovebox $30 SOLD
HICAS computer $50 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $40
boot release with fuel flap popper $40
side mirrors $50 each
bonnet squirters $20 pair
bonnet heatshield $60
A,B,C pillars
clutch master $40 SOLD
brake booster $60
accelorator with cable $50 brake and clutch pedals $30 each
steering rack $150
metal plate that goes inbetween rear seat and boot $60 SOLD
windscreen wipers $30 pair SOLD
window wiper motor $40
overflow and washer bottles
kickpanels $20 each
assorted cooler piping from gtr $50
wheelnuts $25
seatbelts
rearseat in mint condition $150
boot rubber seal perfect cond. $40
drivers door window switch $50
rb20 crossover piping $40
turbo timer exc. working order $30 SOLD
handbrake $30
random 8 inch subwoofer never been used $20
pair of 16 inch 4 stud rims with good tyres (perfect for skids) $100
This is a VERY brief list of wots available
Pictures on page four, whole underside of car is still there, taking offers on everything and anything
front pipes $100
sunvisors $20 each
interior lights $40
dash loom $100
interior carpet $70
brake calipers rear pair only $150
steering wheel $50
GTR fuel pump exc. working order $90
glovebox $30 SOLD
A,B,C pillars
brake booster $60
steering rack $150
kickpanels $20 each
wheelnuts $25
seatbelts
handbrake $30
pair of 16 inch 4 stud rims with good tyres (perfect for skids) $80
Indicator stalk SOLD
1 of 2 intercooler mesh's SOLD
have been letting stuff go for dirt cheap, need it all gone asap
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
