I had the same problem. It ended up being two much endfloat of the compressor shaft. The clutch of the compressor will not engage when this occurs. I found a second hand one and haven't looked back - i thought toyota nippon - denso air was good but this is colder. good luck
goto http://www.meggala.com/ and I think there is an aircon diagnostics running sheet on there, tell you how to get into diag mode and should give you a list of error codes to tell you what is failing...
cool dude will check it out.. thanks
