  • Replies 50
Posted Images
Anything bigger than stock is going to be better mate.
That is just simple logic.
I'd take a stab your car is faily standard, so just get whatever 3.5" CAT is cheaper really.
Wont be much between them.
I recently asked Just Jap about their entry level 3" cats for an R34, the flow rates are as follows:
X force claim 570cfm and Catco claim 428cfm.
These are for the ceramic cats, not metallic. Note that 'stainless' refers to casing not catalyser type.
I went with the XForce in the end due to (claimed) higher flow rate. So far so good.
Edited by V28VX37
Whats the difference between ceramin and metallic when it comes to cats?
Metallic ones flow better & last longer AFAIK. They're plenty more expensive too, roughly double the price of a ceramic one for a 3" XForce.
Yeh, try putting a ceramic cat on a car that melted a metallic cat. It wouldn't last 2 weeks.
High quality metal cats will take a lot more heat than cheap metal cats, don't stinge out on your cat.
Hello
I wanted to get everyone's opinion on how good the Catco and X-Force high flow cats are. Are they better than stock?
I've the X-force CAT, it got it as a pack with my 3.5" turbo back exhaust.There is definitely a improvement over the stock system & CAT.
If you car is heavily modified then get something better, but for near-stock cars then it is good.
Edited by Mayuri Krab
Well, cat prices start at around $150 at the cheap end and I just checked Nengun and they have plenty in the US$1000+ range (with a HKS set for the R35 at US$5k+!)
You can get a complete turbo back exhaust system for under a grand using second hand parts, or you can easily spend 5k and above for the same. I reckon the value of the car plays a role too, I wouldn't spend 5k on the exhaust for a 10k car ... 100k car is a different matter of course :)
Horses for courses I suppose.
I have a 3" Xforce ceramic cat for my 32 that I only use for the pits. It's shit. Turned my 3L from an insanely responsive torque monster into a doughy POS, and that was only with 183rwkw.
My Stagea came with a welded in Xforce metallic cat and that collapsed a few months ago :)
So are the Catcos and XForces any good? Some say they are and now some are saying ceramic ones will melt?
This.
I'm currently looking to complete my cat-back exhaust to turbo-back. For what its worth, the advice I've been given is to avoid both Catco and X-force, and go with MetalCat. Obviously you'll have to spend more for a MetalCat, but like anything I guess, you get what you pay for.
Also, regarding the flow rates that are often quoted, remember that these usually aren't worth the paper their printed on. One cat might quote say 1000CFM, but won't tell you that the bench flow rate was 4000CFM or something ridiculous. Alternatively, another cat might quote 500CFM, using a bench flow rate of 1000CFM. So the second cat is actually twice as efficent (50% vs 25%), but first cat manufacturer will still claim that their cat is better, quoting the higher flow rate. So only take a CFM value onboard if its provided in the context of the flow rate of a straight through pipe (of the same diameter) for reference (and good look finding such data on the internet, though if you do, pass it along, lol).
Well what's the difference between ceramic turbines and steel turbines? What happens to a ceramic turbine when you boost too high and create too much heat?
What's the solution? Steel turbine. So what do you think the difference will be when it comes to ceramic and metal catalytic converters?
Edited by Hanaldo
Catco's ceramic cat is 428cfm, but their metal cat is 706CFM. I went the catco metal cat (706CFM).
Claimed flow rates are all bullshit unless they tell you what pressure drop (through the part under test) they were done at.
very very few manufacturers state the pressure figure.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
