I need help ,my indicators didnt work since this morning...they stoped working,but getting to work they started again...so though nothing happened .
In the afternon they didn't work at all checked fuse it was OK...so HELP ME...please.
https://www.sau.com.au/forums/topic/332562-helpmy-indicators-are-not-working/
Cannot find it ...How does it look?the only roundish things are 2 small cilinder under drivers kick panel # TD107-2?
Sorry looks like it's square in Stageas. 25710 or B in the attached pic. part number 25731-AG000 Genuine should be around $25 maybe?
hope this helps!
After looking for that part I found this ...looks the same but numbers are different,It reads:
NILES
IF356 Japan
12.6 V 85C/M
T/S 54w
H/W T/SX2
DOT
and at the other side e13
020301
9629N
Checked it with the multimeter,but no reding between any of the terminals...
Can it bet it? Just in case attache a pic. BTW forgot to say it's a 1999 RSFOURV S2 STAGEA...
Edited by southern_tango
Yep that would be it! Sometimes they just need a bit of a tap to get going again. That's assuming the problem lies in the unit and not somewhere else.
Thanks a lot ,you've been of really great help...BTW where did you get the FAST?
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
