GorgoniteMan Posted August 11, 2010 Share Posted August 11, 2010 Hi im a newbie, im looking to get some coilovers and wondering what people think of the tein super streets? My car is a daily, but im still looking for the best performance possible whilst staying within a reasonable budget. also, does anyone know how much these coils can be lowered? not looking to absolutely slam but def needs to go lower. cheers Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/ Share on other sites More sharing options...
Craved Posted August 11, 2010 Share Posted August 11, 2010 they are a nice ride - and go go lower than legal easily enough Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5394026 Share on other sites More sharing options...
george_afc_23 Posted August 11, 2010 Share Posted August 11, 2010 A couple of my mates have the super streets in their cars and as far as comfort goes they give you quite a reasonable ride...as for performance im not 100% sure how effective they are but i'd say pretty good from the couple of times ive driven their cars. Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5394198 Share on other sites More sharing options...
Dani Boi Posted August 11, 2010 Share Posted August 11, 2010 (edited) I've got them in my car and for a street driven car they are awesome. I've got the aus spec ones so the spring rate is a little softer than the jap ones but the comfort is really good and firm. Best modification I have done by far. And yes you can lower them a lot, my rears tyres are sitting on the guard and there is probably about another 20mm of adjustment in there Edited August 11, 2010 by Dani Boi Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5394381 Share on other sites More sharing options...
turboedsloth Posted August 11, 2010 Share Posted August 11, 2010 As above with Dani Bois comment, they are an excellent unit, have had them installed for 4 years now and they are still going strong Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5394800 Share on other sites More sharing options...
GorgoniteMan Posted August 12, 2010 Author Share Posted August 12, 2010 thanks for the comments dani boi, what spring rates have you got? Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5395785 Share on other sites More sharing options...
GDZ-14R Posted August 12, 2010 Share Posted August 12, 2010 Aus spec's are very comfy and cushy, a lil on the soft side though for any track work. If you like guard close to rubber low - they won't do it. I hate how jacked up my rear is and want to get rid of them for that reason alone... Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5395791 Share on other sites More sharing options...
Birds Posted August 12, 2010 Share Posted August 12, 2010 Get the Jap specs...can't tell much difference between Aus and Jap, it's negligible. Jap are cheaper... Good coilovers they handle quite well when set to firm. Street ride is decent on most roads, only on cracked or tram tracked roads will it feel uncomfortable. They will also make you notice any creaks you have in the rest of your suspension/chassis. Alas a hundred opinions have been posted around these forums, search function is your friend. Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5395855 Share on other sites More sharing options...
Brandon Posted August 12, 2010 Share Posted August 12, 2010 Get the Jap specs...can't tell much difference between Aus and Jap, it's negligible. Jap are cheaper...Good coilovers they handle quite well when set to firm. Street ride is decent on most roads, only on cracked or tram tracked roads will it feel uncomfortable. They will also make you notice any creaks you have in the rest of your suspension/chassis. Alas a hundred opinions have been posted around these forums, search function is your friend. +1. All that crap about being softer than Jap might be true but its negligible for the 1k saving. The Jap spec SS are even softer than my stock v-spec suspension when they're set to 1/2 the damper setting. Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5395932 Share on other sites More sharing options...
Dani Boi Posted August 15, 2010 Share Posted August 15, 2010 +1. All that crap about being softer than Jap might be true but its negligible for the 1k saving. The Jap spec SS are even softer than my stock v-spec suspension when they're set to 1/2 the damper setting. Not too sure about the 1k price difference, maybe $300? Maybe you are comparing Jap ones without the pillow tops to the Aus ones with the tops and yes the spring rate difference is neglible. Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5399696 Share on other sites More sharing options...
Brandon Posted August 15, 2010 Share Posted August 15, 2010 Not too sure about the 1k price difference, maybe $300? Maybe you are comparing Jap ones without the pillow tops to the Aus ones with the tops and yes the spring rate difference is neglible. Fulcrum quoted around 2.3k for them and I got them straight from Japan for 1450 delivery. And yes they have pillow top, full Super Street Kit. Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5399756 Share on other sites More sharing options...
Pattygtst Posted August 16, 2010 Share Posted August 16, 2010 (edited) I am getting mine from a local supplier for under 2k but even on nengun its just over 2k delivered. Plus you get warranties when purchased and installed locally. Where are you getting that 1450 delivered price from? Edited August 16, 2010 by Pattygtst Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5401208 Share on other sites More sharing options...
Brandon Posted August 16, 2010 Share Posted August 16, 2010 I am getting mine from a local supplier for under 2k but even on nengun its just over 2k delivered. Plus you get warranties when purchased and installed locally. Where are you getting that 1450 delivered price from? Through a mate that import straight from Japan's distributor (all prices quote are in YEN). You're simple ditching a bigger middleman (e.g. RHD, Nengun etc, maybe paying 30-50% mark up?) and paying a smaller middleman going my way (maybe 10-20% markup?). If you're overly concern about warranty, just get them locally. Just gotta manage your risk and if you think its not worth it, pay that extra and get them locally. Obivously I think otherwise. Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5402526 Share on other sites More sharing options...
Zardz15 Posted August 17, 2010 Share Posted August 17, 2010 hey guys, the original poster is my brother. thanks for all the input, been really helpful. however we've decided to go either greddy type s or silkroad rm8's for my bro's r33. the reason is, we think the ss wont go as low as we want, but also ive had the greddys in my previous s15 and currently got the silkroads in my s13. around 1650del for either one. anyway for those interested in the tein ss, i got quoted 2500 from a local fulcrum supplier (umm, no!) and about 1950 from cj motors in brisbane. im assuming Brandon you used streeter? i use him for everything too mate, cant go wrong. Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5403646 Share on other sites More sharing options...
PM-R33 Posted August 17, 2010 Share Posted August 17, 2010 (edited) Not sure how low you want to go I have them in my car and the car is pretty low and could go lower. The Greddy Type S are good aswell though. Also for a R33 the Jap Spec and Aus Spec Superstreets have the same springs rates, 4kg. It's the valving which is slightly different. Here's a thread about them. http://www.skylinesaustralia.com/forums/Te...et-t319284.html Edited August 17, 2010 by PM-R33 Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5403943 Share on other sites More sharing options...
Brandon Posted August 17, 2010 Share Posted August 17, 2010 hey guys, the original poster is my brother. thanks for all the input, been really helpful. however we've decided to go either greddy type s or silkroad rm8's for my bro's r33. the reason is, we think the ss wont go as low as we want, but also ive had the greddys in my previous s15 and currently got the silkroads in my s13. around 1650del for either one.anyway for those interested in the tein ss, i got quoted 2500 from a local fulcrum supplier (umm, no!) and about 1950 from cj motors in brisbane. im assuming Brandon you used streeter? i use him for everything too mate, cant go wrong. Yea mate you cant wrong with streeter. Link to comment https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/#findComment-5404236 Share on other sites More sharing options...
