Hi im a newbie, im looking to get some coilovers and wondering what people think of the tein super streets?
My car is a daily, but im still looking for the best performance possible whilst staying within a reasonable budget. also, does anyone know how much these coils can be lowered? not looking to absolutely slam but def needs to go lower.
cheers
https://www.sau.com.au/forums/topic/332571-tein-super-streets-for-my-r33/
A couple of my mates have the super streets in their cars and as far as comfort goes they give you quite a reasonable ride...as for performance im not 100% sure how effective they are but i'd say pretty good from the couple of times ive driven their cars.
I've got them in my car and for a street driven car they are awesome. I've got the aus spec ones so the spring rate is a little softer than the jap ones but the comfort is really good and firm. Best modification I have done by far.
And yes you can lower them a lot, my rears tyres are sitting on the guard and there is probably about another 20mm of adjustment in there
Edited by Dani Boi
Get the Jap specs...can't tell much difference between Aus and Jap, it's negligible. Jap are cheaper...
Good coilovers they handle quite well when set to firm. Street ride is decent on most roads, only on cracked or tram tracked roads will it feel uncomfortable. They will also make you notice any creaks you have in the rest of your suspension/chassis. Alas a hundred opinions have been posted around these forums, search function is your friend.
+1. All that crap about being softer than Jap might be true but its negligible for the 1k saving. The Jap spec SS are even softer than my stock v-spec suspension when they're set to 1/2 the damper setting.
Not too sure about the 1k price difference, maybe $300? Maybe you are comparing Jap ones without the pillow tops to the Aus ones with the tops and yes the spring rate difference is neglible.
Fulcrum quoted around 2.3k for them and I got them straight from Japan for 1450 delivery. And yes they have pillow top, full Super Street Kit.
I am getting mine from a local supplier for under 2k but even on nengun its just over 2k delivered. Plus you get warranties when purchased and installed locally.
Where are you getting that 1450 delivered price from?
Edited by Pattygtst
Through a mate that import straight from Japan's distributor (all prices quote are in YEN). You're simple ditching a bigger middleman (e.g. RHD, Nengun etc, maybe paying 30-50% mark up?) and paying a smaller middleman going my way (maybe 10-20% markup?).
If you're overly concern about warranty, just get them locally. Just gotta manage your risk and if you think its not worth it, pay that extra and get them locally. Obivously I think otherwise.
hey guys, the original poster is my brother. thanks for all the input, been really helpful. however we've decided to go either greddy type s or silkroad rm8's for my bro's r33. the reason is, we think the ss wont go as low as we want, but also ive had the greddys in my previous s15 and currently got the silkroads in my s13. around 1650del for either one.
anyway for those interested in the tein ss, i got quoted 2500 from a local fulcrum supplier (umm, no!) and about 1950 from cj motors in brisbane.
im assuming Brandon you used streeter? i use him for everything too mate, cant go wrong.
Not sure how low you want to go :P I have them in my car and the car is pretty low and could go lower. The Greddy Type S are good aswell though.
Also for a R33 the Jap Spec and Aus Spec Superstreets have the same springs rates, 4kg. It's the valving which is slightly different.
Here's a thread about them.
http://www.skylinesaustralia.com/forums/Te...et-t319284.html
Edited by PM-R33
Yea mate you cant wrong with streeter.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
