Sort of get it now. For eg, if i were to set the high boost at 12psi on the controller, what it does is to trick the actuator into keeping closed until boost pressure reaches 12psi and then the controller will do as what paulr33 describes as "tell the actuator to open" and the actuator will open up the wastegate to regulate the pressure. Or else, without the controller, the actuator will always open up at 7psi and boost pressure can't go up anymore. The controller does the same thing for any boost setting.
Is my understanding right? Please correct me if wrong anywhere. Also, if the actuator will always open up at 7psi without the use of a controller, then why do most of you guys use an aftermarket ecu other than rearranging the fuel map for tuning?
yep, you seem to be getting it :( . the reason for upgraded ecus, is that theres only so much the stock ecu can do, it doesnt really have any capability for tuning. and it will hit R&R on quite minimal mods (intercooler exhaust etc). also one of the major factors is that it dost support uprated injectos (therefor not much fuel = not good lol), E85 tuning and better fuel economy even. the list could go on forever. have a search on ecus ie nistune link etc. you will see the capabilities these things have. just keep reading :blink:
yep lnah you got it spot on
there are some other things to note
you can't run less boost the actuator spring
ie you cant make the car run 4psi if you have a 7psi spring
because when you floor it, boost will increase until the actuator opens
so you cant make your controller (or any) give you less boost than the spring in the actuator, only more
and the best setup is to run the ideal pressure target in the spring actuator and bleed 1 or 2psi you need
ie dont use a 7psi and use a electronic controllre to run 22psi - its too much work for controller
if you wanted to run 22psi you would change the actuator to an 18psi actuator and bleed 4 psi
but this means, the minimum boost you run when you floor it (and the engine builds pressure) is 18psi
I see. Sort of get a rough picture of why you all say that squeezing extra power involves much more than just a simple mod to the air filter and exhaust. The air filter and exhaust are probably just the bare minimum, imo. More like setting up for the steps that follow on.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
