PM me with what your after.
IGNITION COILS
MAIN LOOM
ENGINE BAY LOOM
BONNET RELEASE CABLE
STEERING COLUMN WITH IGNITION SWITCH AND HKB BOSS KIT
THERMOSTAT CAST
WATER INLET CAST
BRAKE / CLUTCH / ACCEL. PEDALS
DOOR LOCK TIMER
CLUTCH FAN
HEAT SHIELDS
FUEL TANK
HEATER LINE
SPEEDO CABLE
SIDE SKIRTS
"SKYLINE" DOOR TRIM
"TWIN TURBO" PIPE
COILOVERS
RADIATOR COOLANT RES.
WINDSCREEN WASHER RES.
POWER STEERING RES.
CHARCOAL CANISTER
SEATBELTS
SIDE REPEATERS AMBER/ORANGE
FUSE PANEL VENT
FACTORY BOOST SOLENOID
THROTTLE POSITION SENSOR
ASH TRAY
CAMS
INLET SANDWICH PLATE
ALPINE TYPE S 6.5" COMPONANT SPEAKERS
ENGINE MOUNTS
HEATER / AIRCON CONTOL (UNDERDASH)
AIRCON ELECTRONIC CONTROLLER (DASH)
ABS MODULE
AIRCON TEMP SENSOR
ENGINE WIRING LOOM
ALTERNATOR BRACKET
FUEL FILLER COVER
STARTER MOTOR
POWER STEERING PUMP BRACKET
AIR CON PUMP
https://www.sau.com.au/forums/topic/332585-whats-left-from-my-32gtr-wreck/
hey buddy, any chance u have the surround for the CD player the black bit, also gose down and around the gear shifter... i can post a pic if u need it.
