  • 3 weeks later...
i recently had a brake place make up lines for me, for both fronts was less than $50. Get them to make them straight out of steel and bend them youself in the car so if they dont fit its your own fault :D
Really was easier than i thought it would be. ring around
Hi
Just wondering if the R32 GTR brake lines are the same as the R33 gtst, (just the end which connects to the body main connects near the calipers?)
Cheers
If you just mean the actual fitting that goes into the caliper, then yes the thread/fitting is the same. What are you trying to do?
Have a look in the DIY thread for my tutorial on how to install braided brake lines on a GTST. There is plenty of photos of the stock setup and the braided brakes lines getting put on. Hopefully the photos answer any questions you may have.
Edited by PM-R33
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
