Hel Stainless Steel Braided Brake Line Group Buy #2!
PM-R33
 Share
  • Replies 165
Posted Images
It's just the black sleeve that has the wording FMVSS-106 on it at the end of each brake line, that's it (you all have them as I checked each kit to make sure). Part of ADR is to have that sleeve on there but it isn't just that sleeve that makes it legal, it's the way the entire lines are constructed.
I went over it a bit in the old group buy thread but at the end of the day I am only limited to my own research I have done on the subject, if any one wishes more technical information about them just call Hel Australia or Hel UK.
Edited by PM-R33
Is it best to go to a brake specialist to install the braided brake-lines.
Who in Brisbane?
Have never done this and don't want to screw this up else it might be the last thing I ever do !
How may hours to do front and back replacement on a 1996 non turbo skyline?
Whats a reasonable cost?
Edited by samuri
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
