So my R34 GTR with GTSS', poncams/gears, Z32s, pfc, HKS/Nismo dumps-pipes-zorst, bigger cooler, hard pipes, profec, splitfires, etc. made a poor 290awkw with some serious boost issues. Big plug to Unigroup who seem to have sorted the boost issues that i struggled to find on my own...
Now i am up for a decent retune and am seriously considering jumping on the E85 bandwagon, since there are some good supporting mods to start with. My fuel setup is all Nismo, including intank pump, 600cc inj's, and reg. I was thinking bout upgrading to 1000cc ID's, running E85, 22psi+, and aiming for mid 300's at the wheels.
What do you guys think of running the Nismo intank with 1000cc ID's to support the power level, and also doing it on standard bottom end?
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/
  • Replies 87
Posted Images
Id be getting a small undercar surge tank and one 044 pump or similar should do the trick for that power level..Only cost about 300$ too, cheap for peace of mind..
If you get the latest PI magazine theres a story on it, and a free dvd... :D
Edited by Arthur T3
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394509
If we're talking only one 044 pump, wouldn't the Nismo pump be close in flow rate comparison?
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394524
i cant see why you cant make 300-330ish with the setup you have on just 98.... is the extra 20-30kw really worth screwing round buying e85 all the time? Unless its at a servo near you... or the car is track only....
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394553
In the perfect world it would make 330awkw, esp with all the brand name bits on it... It only made 290 and drove like a pig, although the old tuner was clueless and ignored the boost issues too. Just want to make sure it reaches its potential, and the possibility of it exceeding expectations and making something silly like 370+ would be insane!!
Servo in the next suburb is selling E85 as of next month.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394577
Sard 700's (or the 800s) would be fine for that power. Minor rail bump if anything.
I think Nismo have 740s for RB26's as well?
Nismo pump flows fine for 400rwkw on PULP/700cc + a minor bump (circuit cars, no surge tanks in them)...
So E85 @ roughly 360rwkw would be similar in terms of volume/supply
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394579
Most you'll get is around 30-40rwkw gain from E85, going by what most other results indicate at least anyway :D
So 370 would look like the limit (in theory).
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394585
Your lucky man, i gotta drive 1.5hours into the city to get E85. But im pritty sure holden realised some Eco crap last week that runs on E85 so hopefully it comes more avaible.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394592
You could always put a big single in tank like an A1000 for that power it shouldnt be stressed and then no extra lines and tanks etc
Thats an 800$ pump, for that you get 2 44s and a surge tank...
Maybe I just like surge tanks, but thats how i was going to set mine up anyway..
You dont think its worth it?
:D neither does nismoid.....
Edited by Arthur T3
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394598
By any chance do you get your car serviced at Autostyle? I sort of recognise the plates
Most people will say you need an extra 30% for E85, thats not always the case, my car proved it was way more than 30% under full throttle, but then again every setup is different :D
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394617
^ depends on how efficient the setup is and all the usual variables that come into account :D
Some cars respond much better to fuel and all of a sudden you can get heaps more out of it, same token fuel use then is higher also.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394625
Here is the link to Caltex planned rollout of E85:
http://www.caltex.com.au/ProductsAndServic...s/BioFuels.aspx
Marketing manager told me plan is have most running by late September, early October. So that might make it easier for some.
Engine bay looks almost stock, i don't want the look of pumps, lines, surge tanks in the boot.
The 740's are side feed Ash. From what you describe pump maybe close to a dangerous limit there.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394632
Thats why i said undercar tank...can get one that holds 2 44s..bolts up under the boot floor
135$ on ebay.. ..
http://cgi.ebay.com.au/Fuel-Surge-Tank-Und...=item3356ba225b
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394651
You mentioned unigroup fixed your boost issues, what sort of power is it making now?
The car should be making in the region of 320-330awkw with the hardware you have currently, and if not, somethings not right and I would be addressing that before trying to chase more power through switching to E85.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394652
Haven't been back on the dyno, currently sitting outside holding off for a week to decide whether or not to go E85.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394659
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
