Hi Guys,
Just need some advice on tyre sizes, I have just ordered some new TE37 18x10.5 +15 for my R33 GTR
i have been recommended 265/35/18?
Any help would be much appreciated.
And i just realised i just posted in the wrong section! :)
Edited by -BCNR33-
https://www.sau.com.au/forums/topic/332646-tyre-choice/
You want tyre choice or tyre sizing?
Tyre choice I went for Kumho's as they are an all round decent tyre.
Tyre sizing, what ppl have mentioned above.
Any information will help what would be the best tyre for around $375-$400 each im not looking at spending big $$
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5395297
KU36 is within that price range. I'd go 285/35 or 275/40. Just guesstimate. I dont think you'll need any guard work but it normal for drivers side to scrub when doing a full lock right turn unless you have adjustable rods.
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5395420
I had a quick look on the Kuhmo Australia website and they dont list a ku36 in a 285/35/18?
Any other options?
I dont want the stetch look.
Thanks :P
Edited by -BCNR33-
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5395483
Any other options?
Thanks :P
Hmmm... yea from the looks of it. Even Federals doesnt make 285s. Maybe try calling some tyre shops. I'm running Bridgestone Potenza RE050A 285/30/18 and I think they're way too exp...
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5395578
Like what Brandon said, that will get you a set of decent tyres.
Any other options?
Thanks :P
You might have to head down to your mechanic / tyre place to see if they can sort out a set.
Don't have to be KU36's, anything in the Kumho Ecsta range will do you fine.
I assume your car is for street use..?
Depending on how low you ride height is, that is when you need to worry about guard work.
Only roll / flare your guards if you want the Hellaflush look, which I assume is not what you want, cuz to go Hellaflush, you need to stretch your tyres.
As long as you fill out your guards and the ride height / wheel arch sits just above the tyre, you will be fine.
You got fully adjustable coilovers?
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5395581
Yea my car will mainly be used for street, i wont be looking at having the car heaps low just at a nice height and i will be using Greedy type s coilovers.
Ill ring around and get a few prices on 285/35/18 in the Kuhmo Ecsta range.
Thanks for all the help! :P
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5395607
No worries!
:P
Post some pics when done.
I have the same wheels but in 17 x 9 +22 ;)
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5395822
No worries!
:P
Unfortunately the wheels are being made atm due to the size not being made of the shelf :(
When i get them around January i will definitely throw some pictures up! :D
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5395946
18 x 10.5 is a custom sizing?
So you take it to a wheel specialist and they re-widen the wheel?
I bought the wheels through Jesse Streeter and i was told there isn't stock available and had to be manufactures in that size.
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5397168
Ok so you ordered wheels from him and he is getting the custom made up for you before he sends it over from Japan?
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5397243
Ah ok, I get you now.
Worth the wait I guess... :P
Or you could have got the next size that was available to that and use a small spacer...
I didn't really want to use spacers as its a bit of mucking around i just wanted something i could put straight on and look good
It's worth the wait as im still waiting for the car itself! :D
https://www.sau.com.au/forums/topic/332646-tyre-choice/#findComment-5397284
