  • Replies 80
hey guys; don;t let me run on my own meet me at eastern creek drags, tommorow night.
lets see what the m35 do stock ,except for my exaust. :thumbsup:
rudi ..
Hehe i only got my m35 last week, but id like to see what it does stock also :blink:
I'll be interested to hear what you pull.
(stock m35 with vq25det driveline)
M35's can launch? ;)
have you seen this stocky NM35 with a full tank of fuel and baby seat removed eating commodores and getting 13.5 on the quarter out of 4 runs that another dude posted on another thread.
Always gonna launch reasonable with awd and such a heavy vehicle :)
Edited by PetroDola
I think you'll find thats Scotts car ;)
:touch: Scott! You didn't tell me you removed the kids seats!
I thought Jack was in the back for those runs (he would've loved it!)
I couldn't find a helmet small enough mate. :D
lets go guys wednesday is the day; too much talk on what mods have been done. time to prove it
i;m going to be there 6.30 just before the pay gate if you all want to go together the same time.
rudi >_<
rudi >_<
Going straight from work, might be there a bit earlier, I'll keep an eye out for ""Big Girls" :D
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
