  • Replies 80
I'll be trying to make the next one......just got to do two little things first :)
Handbag and matching heels? (Jokes, jokes)
Hurry up, I wanna see what it runs.
After seeing our times and terminal speeds, I'm even more in awe of what scotty has achieved.
hey guys was an awesome night was very busy due to cancelation last week but perfect conditons .
was good to catch up ith the satgea boys who SHOWED up :) lol...
these heavy car can launch great
my first run i got a 2.033 60ft and 14.566 @ 150.41
second run was a 2.026 60ft and 14.435 @ 152.19 :)
beating a r32 gts-t with mods on both runs :)
was very happy with my result considering i only have an exhuast!
cant wait to go agin hopfully a bigger group next time
thanks to the boys that showed was a top night
i have set the bar at 14.435 ( for basic mods ) ... lets get a bigger group down there!
cheers rudi
cheers rudi
Thats awesome rudi..gotta be happy with a 14.4 for just a zorst :)
Cant wait till mine arrives...wish there was more m35's here to have a meet at willowbank!
Maybe in the future can get some s1's down there also ;)
hey guys have any of you done a 400m time? i;m thinking of taking it to eastern creek :P
hey all now i;m back in sydney i did a check on my fuel reading at the end of 400m and it was 23l/100.
and yet to post pictures when i was up against a skyline r32 in the drag. yes i won !!!!!!!!!!!!!
cheers
  • 3 weeks later...
Well Spoolin and I went out to WSID last night and popped our drag cherries in the stags!
Had a blast, but it was so busy we only got a couple of runs in over the 4 hours there! So we are itching to get back and better our times. But great fun.
I had one decent launch but I think I backed off before I passed the line, because my mph was lower than my slowest run...? which doesnt make sense to me.
Best run was:
60' - 2.007
330 - 5.897
1/8 - 9.185
1/4 - 14.468
MPH 93.89
Km/h - 151.10
Only modification is cat back exhaust. So I was happy to get lower than 14.5
Ben.
Edited by bbenny
Very well done, thats the best 60 foot time we have seen is it? I think it comes down to how you throttle on, definitely cant just mash it.
Wheres the pic of the burnout? Oh wait thats right... ;)
With the Impul you just might get there, no speedlimiter vs scottys speed limited run :P
I think the speed cut is still there, the Emanage speed wiring isnt hooked up so I cant adjust the speedo either. Looks like I will need to crawl under the dash again.
Best run was:
60' - 2.007
330 - 5.897
1/8 - 9.185
1/4 - 14.468
MPH 93.89
Km/h - 151.10
Ben.
well done benny. i just beat your time i did a 14.43. good to see more stageas get out there :P
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
