take it back?
how bad is it pulling? every car is going to pull a bit. im not gonna get into this too much i remember seeing a similar thread which its all covered in, pretty sure was in the WA section too.
edit: read ---> http://www.skylinesaustralia.com/forums/Ca...-W-t329747.html
Edited by jimmys-33T
https://www.sau.com.au/forums/topic/332744-wheel-alignment/#findComment-5396435
he means take it to brad at wa suspensions.
where did you get the wheel alignment? most shops dont even drive the car when doing them so have no idea how straight it drives.
We do road test the cars.
We drive them around the block. However being Osborne park its not often a speed of over 60 kph can be reached. We always check the steering wheel is straight etc.
As most know, Skylines do not have any Castor adjustment...they will all pull left on our cambered roads unless Costor bushes are installed. Or, go all out and get some Casotr Rods to gain adjustment
https://www.sau.com.au/forums/topic/332744-wheel-alignment/#findComment-5397047
yer i know you guys do, just saying most dont.
https://www.sau.com.au/forums/topic/332744-wheel-alignment/#findComment-5398000
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
