Hi to all,
Finally, just got my v35 250gt last thursday. I've been observing it for a week now, so far it's all good. There's just this one thing bothers me about my breaks. The car vibrates a little bit whenever I slightly step on the break pedal to slow down coming off from 80-100 kph.
Is this normal? Anyone had the same experience before? Am I just making a big deal out of it? Coz the car drives awesome and the breaks are working really well, except only for that little vibrate thing that I'm worried about.
Any suggestions and recommendations of what to do would be big help for me. Thanks!
https://www.sau.com.au/forums/topic/332745-brake-issues/
before you shell out your hard earned chasing the worst case scenario, consider giving them a light skim with some wet and dry then a clean with brake cleaner. You may find some pad resin has been left on the disk surface from poor braking habits. This happens when the foot is left on the pedal when the brakes are very hot. If this doesn't cure it then they may need a machine skim. There are plenty of mobile brake mechanics that can do this without removing the disks.
https://www.sau.com.au/forums/topic/332745-brake-issues/#findComment-5398209
Me too have a vibrating brake before on a 4WD, and I found out there's a hair line crack on it. Have to change the whole disc. I was told maybe the crack was due to sudden cooling of the disc. Like after a heavy use, car was send to a car wash where the water jet cooled the disc too fast.
https://www.sau.com.au/forums/topic/332745-brake-issues/#findComment-5398815
+1 for a rotor issue, (most likely warped), as it's the only issue (other than an ABS fault) that will cause vibrations under braking. Does it get worse when the brakes are hot?
Not really, it only vibrates for 1 to 2 seconds if I slightly step on the break pedal and only if I'm driving a bit fast.
I'm thinking if this is a serious problem, I might bring it back to the car yard I bought it from and get it fixed.. Can I still hold them responsible for any problems with the car? Since it's only been with me for a week now and because they told me that it's been complianced so I don't have to worry about anything. Is that possible?
https://www.sau.com.au/forums/topic/332745-brake-issues/#findComment-5402052
It came with a warranty yeah? Depends on how good the dealer is, as a rotor problem (if that's the case) could be dismissed as normal wear and tear. Only 1-2 seconds? Does it then go away completely or just become really faint?
https://www.sau.com.au/forums/topic/332745-brake-issues/#findComment-5402137
I think it does come with a warranty. Well, it should be.. It doesn't get any worse after those few seconds. It's hardly noticeable tho. But I better get it fixed before it cause me bigger problems in the future.. I'll ring up the car yard tomorrow. Thanks guys for the help. cheers.
https://www.sau.com.au/forums/topic/332745-brake-issues/#findComment-5402331
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
