Have seen a few lines and other vehicles going around with their brake calipers painted and think it looks s**t hot.
I searched past posts and came up with this thread and am just wondering if any knows if the websites listed still exist somewhere or if someone knows where i can find more of a instruction set?
Has any one done this to their own line?
Cheers
:D
https://www.sau.com.au/forums/topic/33277-painting-brake-calipers/
Then get a propane or butane torch and gently 'melt' the paint in if you use the hi temp paint as it will be lost to wheel cleaning agents and washing unless heat cured. You could also cover all the important stuff to stop overspray. Curing this way (similar to baking in a paint oven) brings on a glossier finish.
It means stripping the caliper, which aint too big a deal if you are looking to get them rebuilt, but has anyone looked at getting them HPC coated...sure as hell would be more durable then paint, and have apparently helps reduce brake fluid temps...still i think it would be more fashion then performance for most of us
yeah, read the guide - its been covered in "maintenance" a bit.
The "curing" is not necessary actually. Mine is pretty much as good as the day i did it 4 months ago and i've washed, scrubbed, etc. The high temp paint is very durable and can cope with high temps as experienced during braking. Do 10 coats, you'll be right :D
I did mine in gloss black and it looks great but doesnt stand out.
It is infact possible to paint the calipers while they are still on the vehicle. You just have to spend a long time preparing them and masking off various areas.
Use wire brushes, steel wool and brake cleaner in an aerosol can to clean the brakes properly before painting or the paint will flake off.
With respect to the NISSAN logo, i tried two ways to leave it silver. I tried masking it off and cutting very finely with a razor blade and then i tried just spraying the whole thing and cleaning off the NISSAN logo with thinners and a rag.
The thinners+rag method worked about a million times better and gave an outstanding result if you attack the NISSAN logo while the paint is still wet.
I used VHT Brake Caliper paint which i purchased at Autobarn.
Try just painting it all and then use abit of sand paper to rub it back (after it has dried) thats how mine are done. I might re-do them again and put a gloss coat on em.
Oh and...mine says skyline in white...i painted the writing white first...then let it dry then got electrical tape and cut it out in the shape of the letters then sprayed the whole calipers blue....alot of effort cutting and stuff but well worth it :D
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
