  NYTSKY said:
I found this site this morning too. Good info on there.
i was lookiing for e85 and nos and found it,you can put your money on people knowing this site but not telling anyone so they sound good on the E85 subject. lol
Edited by WARLORD
i noticed this site is for the usa just wanted to know do we have a forum that has updates of where you can get e85 ???
i did a search but on here it seems theres still only two places mentioned for vic ??
im getting nistune in october and was thinking of giving e85 a try if theres a local petrol station that does e85 (im in cranbourne )
i know theres a station down here that might concider it if we get enough people comiting to buy it if they make it avalible !!
i was talking to the bloke but as he said there not many people asking for it but im sure if theres enough skyliners in the cranbourn seford karingal area we might be able to convince them to get it !!!
they already do premium for $1.29 (they use shell i think he said )
all states mate, there atleast 5 new servos with E85 pumps in each state. Some even more... and it will only get more comman just need acouple more eco box's to come out runing on e85 and all servos will have to sell it. It will be like the next LPG......
Im just down the road, there wont be one near us for a while unfortunately. Blackburn road would be the closest Caltex or just go to Southland.
i recon we can convince apco to get it
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
