Hey Guys,
Since I can't sell my car for the price I want it for, I'm going to return it to stock and sell it and whatever price people are willing to pay for it.
So....... I'm going to sell my aftermarket parts provided you trade in your stock parts all in one go.
I'm after $3300 for the above with your stock parts traded in, big saving, think about how much these parts WOULD cost.. You're going to save $650!
$1300 - PowerFC & Hand Controller (have original box & manual)
$500 - PowerFC Boost Kit (have original box & manual)
$1200 - HKS 2535 Turbo with Braided Lines
$400 - Splitfire Coil Packs for Series II RB25DET
$200 - Z32 & Plug
$350 - 6x S15 450cc Injectors
Of course I would require:
- stock turbo
- stock turbo lines
- stock coil packs for Series II RB25DET
- stock afm
- stock afm plug (you're gonna chop yours off anyways to use Z32
- stock boost solenoid
- stock injectors
- stock ECU
We should be able to swap over the lot in under 1 day.
Comments: Will Sell as package only, and firm on price
Cheers,
Johnny
Edited by johnnilicte
Hey Guys,
$200 - Z32 & Plug
- stock turbo
- stock turbo lines
- stock coil packs
- stock afm
- stock injectors
- stock ECU
Cheers,
Johnny
i can do coilpacks provided they are for the series 1 R33.. i can bring car around tomorrow morning since ill be in the area
EDIT - sorry didn't see you are only selling as package
Edited by NicsR33
Hey john, will you sell the Z32 + Plug ?
got Rb25 S2/ /R34 RB25 pink label AFM + plug to swap + cash on top
i know it says package only but its worth a shot.
Hi Mate,
I don't mind selling bits and pieces, provided I can get my car running.
PM me!
Cheers,
Johnny
Ideally I can swap Z32/Coilpacks/Turbo/Injectors and then ECU last... I have another club member in VIC who might want it, I see how that goes!
hey mate yeah still interested in the ecu and coilpacks but has to be for a s2 what series is the car
It's a Series II, 1998 GTS-t :thanks:
I'll call you tomorrow Abe,
Cheers,
Johnny
Cheers,
Johnny
If you still after some standard coil packs for a series II let me know
  • 4 weeks later...
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
